Originally Posted by
RWOLFEJR
I hopped on Alcoa's site to look at the material properties. My guess is that the relatively large amount of stock removal... as compared to the original cast thickness... was were the problem started. It appears that 1/4" thick may be as small as they will cast? That's as small as they go in discussions of expectations of flatness and thickness tolerances on this stock.
So figuring maybe this stock is as close as you can get for your part requirements, I suppose you might have to find a way to make it work.
Could possibly be that the shop got the part too hot during machining. The relief of stresses at machining should be less in your cast stock than a rolled product but some relief accompanied by heat could add to the warpage. I've heard tell of folks machining thin wall parts while clamped to some material that will act as a heat sink to help draw the heat produced by machining and further reduce warpage. Don't know anything about that though because I've never encountered the need to look further into that.
Could also be a that they took all the extra stock off of one side. That could be the recipe for more twang when released from the machining holding fixture. That isn't to say that this is what happened or that they did indeed remove all the stock from one side only... or that by machining off half the extra stock from each side will necessarily help. Just saying that I'd expect better results in machining if you could purchase the stock cast for minimal clean-up cut and/or dust both sides of the flat legs.
Your solution might be a simple as taking a couple / few light cuts rather than all in one pass? If that still doesn't get it... maybe try a few parts machined on both sides and in a few light cuts each side? I'd also look into purchasing the material closer to size. That's 50% of your material going in the chip hopper.
Good Luck,
Bob
