Thread: Structural Rectangular Spread Footing Analysis
    299
    Program Description: Structural Rectangular Spread Footing Analysis Excel Calculator
    Program Assumptions and Limitations:
    1. This program assumes that the spread footing is in fact "rigid", so that the bearing pressure is distributed
    linearly on a homogeneous soil. (Note: the actual footing is generally not "rigid", nor is the pressure beaneth
    it distributed linearly. However, it has been found that solutions using the assumed "rigid" concept are
    adequate and generally result in a conservative design.)
    Read More: Structural Rectangular Spread Footing Analysis Excel Calculator
    ** Premium Membership Required **
    Download Structural Rectangular Spread Footing Analysis
    May 2013
    thanks for you
    David Burnett
    How do I receive this excel spread sheet
