Thread: Help needed - Secondary Auxiliary view drawing !
    Nov 2013
    I need help finishing this ... I got to draw a primary and a secondary auxiliary view in order to see adequately the oblique surface...
    I guess I understand much of how to do it, the problem is I don't get how to finish this with the hidden lines etc. ...
    Any inputs would be AWESOME !!!!!!!
    Thank you very much
    Engineer
    Nov 2013
    UK
    13
    I don't quite understand the top left sketch. I think it is the view perpendicular to the surface that has been cut, but your lines suggest it is derived from the cross section on the far right. I don't think it helps describe much.
    That far right cross section needs some heavier lines to be complete.
    Personally, I would have added a top view, as I think that would describe enough.
    What is this for?
