Thread: Calculating tipping force?
    newt
    I have a 200cm tall 135kg object that I want to tip over when 65kg is applied at 140cm (see diagram below)
    How do I calculate what length the base (L) should be for this to work?
    Many thanks
    Phil
    Jan 2014
    58
    My Two Cents
    There is more to it than your sketch shows. You need the location of the CG, including its vertical location. When the CG moves over the outside of the base, it will tip. Also, you don't say if the force is radial or stays horizontal.
    Timelord
    Home Work
    Smells like homework to me!
