Actually there is no restriction on the minimum track diameter due to friction because the radial loading to hold the ball against the outer wall is the same at all diameters; and, the smaller the track diameter the less ball velocity required to achieve that force. Also, as long as the ball diameter is smaller than the track tube's X-sectional diameter and track diameter which is inevitable in this arrangement, there will always be an essentially point contact between the ball and the tubing and a hard sphere rolling against a hard surface has essentially zero rolling resistance.
