Thread: Howden refregration package failure
    mustafa2014
    dears all good day,......we are here in a gas plant , we are suffering a lot from the mixing oil with water or condensation in screw compressor refrigeration package. the oil changed to the milky oil and the seal is keeping damaging. by the way the plant is only 5 years old? is any one have an idea? many thanks in advance for you support
    Milky oil color usually indicates contamination with a water or similar fluid.
    The cause of the damage cannot be trouble-shoot with the information you have given.
