The max and min Z values are to help you determine whether failure will occur in the tension or compression face. Consulting your local standards for steel design should solve your woes for this one.
I would recommend going through the moment distribution exercises to get the actual bending stress your angle will experience (which is going to be a lot less than a central max applied force option).
