Thread: lifting davit
    May 2014
    lifting davit
    Kindly advice on the design of lifting davit using galvanised iron bending(G.I) pipe. The lifting davit is removable and its base platesupported with 12mm dia. bolt (4 nos). The height of this liftingdavit is 1.8 m with bending angle 120 degree to the vertical. The G.Ipipe dia. is 80mm.
    canu advice on the max weight/load that lifting davit can withstand?
    Attached herewith is an example of lifting davit.
    TQ
    May 2014
    Thanks
