Thread: need help in coding in atmel studio 6
    Nov 2014
    Unhappy need help in coding in atmel studio 6
    This is my code,this code is for tachometer, i am using atmel studio 6.0 it is giving error in #include"lcd.h".Please help me what to do?
    #include <avr/io.h>
    #include <avr/interrupt.h>
    #define F_CPU 1000000UL
    #include <util/delay.h>
    #include "lcd.h"
    volatile uint16_t count=0; //Main revolution counter
    volatile uint16_t rpm=0; //Revolution per minute
    volatile uint16_t rps=0; //Revolution per second
    void Wait()
    uint8_t i;
    for(i=0;i<2;i++)
    _delay_loop_2(0);
    void main()
    LCDInit(LS_NONE);
    LCDWriteString("RPM Meter");
    Wait();
    Wait();
    Wait();
    Wait();
    //Init INT0
    MCUCR|=(1<<ISC01); //Falling edge on INT0 triggers interrupt.
    GICR|=(1<<INT0); //Enable INT0 interrupt
    //Timer1 is used as 1 sec time base
    //Timer Clock = 1/1024 of sys clock
    //Mode = CTC (Clear Timer On Compare)
    TCCR1B|=((1<<WGM12)|(1<<CS12)|(1<<CS10));
    //Compare value=976
    OCR1A=976;
    TIMSK|=(1<<OCIE1A); //Output compare 1A interrupt enable
    //Enable interrupts globaly
    sei();
    //LED Port as output
    DDRB|=(1<<PB1);
    LCDClear();
    LCDWriteStringXY(0,0,"RPM =");
    LCDWriteStringXY(0,1,"RPS =");
    while(1)
    LCDWriteIntXY(6,0,rpm,5);
    LCDWriteIntXY(6,1,rps,5);
    if(PIND & (1<<PD2))
    PORTB|=(1<<PB1);
    else
    PORTB&=(~(1<<PB1));
    Wait();
    ISR(INT0_vect)
    //CPU Jumps here automatically when INT0 pin detect a falling edge
    count++;
    ISR(TIMER1_COMPA_vect)
    //CPU Jumps here every 1 sec exactly!
    rps=count;
    rpm=rps*60;
    count=0;
    Engineer
    Dec 2014
    Ohio
    10
    May be able to help if you presented the contents of the file ("lcd.h") that contains the error.
