Thread: Need help determining shape and stress.
    Jan 2016
    I am having some serious trouble, I'm in the design phase of building a desk with a full blown Personal Computer inside under a glass top, I have the design down and I know exactly what I want, I just need some help with measurements and knowing how much stress will be put upon the legs. The body is going to consist of solid wood about a 1/4 to 1/2 inch thick.
    The base/bottom is going to be 5ftx3.5ft
    sides are 3.5ftx1.5ft
    and the front/back are going to be 5ftx1.5ft
    the top will be open so I can coordinate a way to place glass on top
    With all the parts of the P.C. and the glass along with the full body, I expect it to be around 45~52 lbs
    I want to build the legs in the shape of an hourglass. (Two legs, left and right) I want the to be 4.5ftx3.5ft (Height*Width) discounting the concave of the hourglass. it would look approximate to two triangles overlapping each other. Considering the shape is made of 4 right triangles I need to know the length of the concave on each side. (overlap I speculate is about a foot)
    I also need to determine the thickness and type of wood based on how much stress would be induced.
    Any help is appreciated, I can post a picture of my schematics as so far if need be, thank you!
    Jan 2016
    More infos
    Quote Originally Posted by kydary View Post
    Hi Kydary,
    Please post a picture of your idea and add up the possible forces which will stress the future table.
    Please put some dimensions and how the parts will be connected.
    Regards,
    Ariel
