Thread: laser microphone
    Feb 2016
    laser microphone
    i am trying to make a laser microphone as my project.for that i am using pulsed laser.so when the pulsed laser comes to the photodetector after being reflected, there will be a shift in the pulse.so can you please help me to obtain those shifted part
    any help in related fields would be also appreciated .
    thanks in advance
    Mar 2016
    Seriously?
    Are you making a Laser mic or laser rangefinder?
    Since your pulses will be coming back phase modulated by time of flight I don't see where you'll be able to extract much audio information.
    You will want to use a PLL (phase locked loop) which if I recall will have a reference input and a signal input and will output a linear control voltage representing the phase error that you can amplify for your "audio" signal.
    Most people use a continuous laser, then pick up a reflected amplitude modulated signal using a telescope and photo transistor or similar. Then it's a straight audio amplification problem after that.
    MB
