You should hire an engineer familiar with your local building codes, and pay him for services rendered.
32 Panel Trapezium dome.pdfI am going to be having a trapezium dome built out of 1/4 thick "2"x2" aluminum tubing with a .063 aluminum skin weight 20,000 lbs is additional bracing needed and how should the panels be joined thanks Rocky
Thank you for your free advice
I was told (by my local Engineer) 1/2 bolts every 2' would be sufficient or a 4" weld every 16"
