None of the options are equivalent.
Per the attached image, which call outs are equivalent, if any?
Thank you!
OK, sorry if I broke a forum rule.
But there is a nameless source that states that CF is the same as a composite position tolerance with the lower segment calling out a geometric tolerance of zero at MMC with respect to no datums.
I now have two credible sources stating different opinions on a standard, which should only have one interpretation.....
I guess I will shy away from using CF until I can find more evidence for its correct use.
Actually - they don't. The presentation video is about how to control two separate hole features as though they are one.. They do not say that the specifications are equivalent or identical.
You should take these questions up with the training materials preparer... At this time you are utilizing Engineers Edge to support somebody else training material.
