Thread: Positional Tolerance on Common
    Jul 2016
    4
    Positional Tolerance on Common Axis
    Hi All,
    A quick question on simplifying a drawing I've picked up for checking.
    See attached concerning a counter-bore thru hole. My view is that I can replace all of that with a single positional tolerance of a common axis, much like ASME 2009 Fig: 7-24.
    I simply want to ensure the co-axial holes align and are perpendicular to the back face. Datum A is the back face but its not shown in the image - again it would be the same as ASME 2009 Fig: 7-24.
    I feel I might get some resistance as my company seem to enjoy adding concentric and circularity requirements to holes. My view is that is adds to inspection costs and doesn't add much, if any functional value to the part.
    What do you guys think?
    Thanks.
    First question... please verify which dimensioning and tolerancing standard this has been specified to..
    Second.. is this the entire specification? Is there only one hole feature intended to be controlled?
    Three, What does Delta Note 3 indicate?
    Jul 2016
    4
    1. None. I have a copy of ASME so that's what I refer to.
    2. Yes, just this hole.
    3. The delta is a revision change symbol. At Rev.03 the GD&T was added.
    And yes, the drawings are a mess...
    May 2011
    Michigan
    78
    Kelly seems to be on to something ... I too suspect that this is not meant to be an ASME Y14.5 drawing, but rather the ISO system. Two clues make me think that:
    -- the print uses commas rather than decimal points
    -- there is a "G7" tolerance, which ASME allows but it's more common in Europe
    So first check on the tolerancing standard (in a note or maybe in the title block?). If it is ISO, then the concentricity symbol has a different interpretation that ASME's interpretation of concentricity.
