Pretty vague drawing... Are the holes all the way through? What are their function?
I'm updating an old drawing with a note for controlling hole patterns, I want to change to modern GDT. heres what the dwg looks like
this is a hopper, it has a hub with a feed screw coming in the left side and a spout on the other side, they want to make sure the two sides are within .060, I want to apply GDT instead of the old school note.
So, your open end request has not been answered and though I know exactly what is required I would like for you to at least attempt to specify the datum structures as well as the related FCF to your design requirements....
I am ASME Certified Senior GDTP, I train, consult GD&T and DFM/DFMA for a living but I'm not going to do your design for you...
https://www.asme.org/wwwasmeorg/medi...fication_title
http://www.engineersedge.com/GDT_Training.htm
So let's see what you got..
this is what I came up with, it just seams more complicated than the original note.HOPPER GDT R5.PDF
Left Side View - Datums A, B are logical based on the information given.. Locating a BC is illogical in this case. You should locate the 4X orbiting holes back to datum's A and B then declare one or all hole features as datum "C".
Right side view - Locating the Bolt Circle (BC) is again illogical.. Depending on the thickness (thin) of the Hopper part, I would simply locate all the hole features back to datum's A, B, and C to the tolerance required.
If the hopper part is thick manufacturing becomes a challenge therefore I would Right Side View declare the outer (or inner) flat surface as datum D, maybe define a parallelism. Then locate the center hole back to Datum's D, B, and C, Then declare that hole datum "E". Then locate the four orbiting holes to datum D, E and C.
Next time you want a high quality set of Michelin tires for your vehicle - simply tell the tire place "put tires on it" and see what you get...seams more complicated
Proper Dimensioning and Tolerancing design is often the difference between a functioning, interchangable, manufacture-able part and something else..
ok see if this is going to work
Total runout? not even close . You need training... At least read my book.
See:
Geometric Boundaries II, Interpretation and Application of ASME Y14.5-2009 GD&T
http://www.engineersedge.com/geometr...ies-2-book.htm
Basic of GD&T training per. ASME Y14.5-2009
http://www.engineersedge.com/trainin...e-training.htm
