Static means that the two flanges are to not move relative to one another. Dynamic means movement and the o-rings are compressed less to allow movement and less friction. For rotation use the dynamic design.
We have an article on static O-rings in a flange arrangement
https://www.engineersedge.com/genera...tic_flange.htm
And dynamic O-rings in a reciprocating cylinder arrangement
https://www.engineersedge.com/genera...c_cylinder.htm
But what does an engineer use in a dynamic flange arrangement? For example, if in the first article, the two flanges were to rotate with respect to each other. Or is there a good reason that this is a very bad idea and I need to redesign things to make it look like the second article? Do just give a little more depth so the compression is only 10-30%? I'm making a high pressure air swivel joint.
Regards,
Harry R. Burger
Mechanical Engineer
CSWP
I may be wrong but I think most if not all of the dynamic seals in standard commercial rotary unions are of the cylindrical type. Have you contacted some of those manufacturers? There's a lot of expertise there, and some of them have probably already done what you're trying to do.
