First or third angle projection?
Hello everybody, new in the forum.
Hope you can help me with this basic doubt.
The attached pdf contains 3 options dimensioning the same part (formed channel)
Can you help me to idetify wich ones are correct or incorrect?
Thanks, appreciate your help!
my 2 cents:
Either 2 or 3 are correct third angle views. Two seems more comfortable.
The 2.50 can be eliminated as it is double dimensioning.
The 5.63 between the two views as on option 3 makes it easier to relate the dimension to front and side views.
There is no call out for the corner breaks.
Thanks for your replies.
All are 3rd angle projection.
I understand that option 1 is not correct.
Greetings!
