Hi and welcome to the forum...
That's quite a kite you're dealing with there. Seems the better idea might be to consult your engineer before you bid...? What if some unknown on the internet whose credentials you have not a clue... tells you to use fifty posts this big by this big and it turns out they were full of it? Then you get the job and find out you'll have to use 100 of those posts...
The cost for the engineers service prior to bidding would be minimal and well worth it... It's called the cost of opportunity.
Good luck...!
Bob
