Hey All
Firstly I would like to say Thank You to the creators of this site for allowing free use of the gear generator.
My issue is that the project I am working on requires a gear set of 112Teeth & 14Teeth gears. I can buy the gears I need in metric ie Module 1, but it's really expensive; around $1000 AUD for the set (including 8 of the smaller gears.)
I see a lot of 112T 64DP gears out there which are really cheap (starting at $10), but I cannot find 14T 64DP gears anywhere. Surely it's not impossible to make them as it can be made in metric/module.
Is there something I am not understanding in the DP range?
Where can I find a 14Teeth Gear to suit a 112 Teeth 64DP gear?
Cheers for your time.
14T 64DP is a very small pinion gear and availability is driven by demand and manufacturability as well.
I suggest that you redesign for the same gear ratio using a pinion that is clearly available from multiple suppliers.
