Results 1 to 1 of 1
Thread: Dimension randomly changes in autoCAD paper space
    Hi all, occasionally our Dim scale linear value randomly changes. Most dimensions on most layouts do not have issues. In the example screenshots below, the viewport scale is 3/4" to 1', so the correct Dim scale linear value is 16. The ~8' dim is correct. autoCAD randomly multiplies by 16 to get 256, and we have to manually input 1 and press enter to get it to change back to 16. The ~49' dim is incorrect. Seems like a simple problem but we spent many hours researching and it seems no one has a solution. This issue only occurs on about 1% of dimension strings, but we have issued some drawing sets with embarrassing non-sensical dimensions because we never know when or where it will crop up.
