U-Tube Manometer Measuring Pressure
Density (kg/m3 , lb/in3) =
Height
Difference (m, in) =
Gravity (9.81
m/s2 , 32.174 in/s2) =
Pressure (N/m2, lb/in2) =
U-Tube Manometer Differential Pressure
Density p1
(kg/m3 , lb/in3) =
Density p2
(kg/m3 , lb/in3) =
Height
Gravity (9.81
Pressure
Differential (N/m2, lb/in2) =
Single-Leg Manometer - Gauge Pressure
Density pm
(kg/m3 , lb/in3) =
Height
Gravity (9.81
Inclined Single-Leg Manometer Measured Pressure
Density pm
(kg/m3 , lb/in3) =
Gravity (9.81
Length (m, in)
angle
(degrees) =
Inverted U-Tube Manometer Equation
Density pm
(kg/m3 , lb/in3) =
Density pf
(kg/m3 , lb/in3) =
Gravity (9.81
Height
