Please enable JavaScript in your web browser for the live calculations to work properly.
Engineering Material Young's Modulus
Gpa
ABS - Acrylonitrile Butadiene Styrene
ABS Flame Retardant
ABS High Heat
ABS High Impact
ABS Plastics
ABS/PC Blend - Acrylonitrile Butadiene Styrene - Polycarbonate Blend
ABS/PC Blend 20% Glass Fiber
ABS/PC Flame Retardant
Acetals
Acrylic
Aluminium
Aluminium Alloy 1100
Aluminium Alloy 2024
Aluminium Alloy 356
Aluminium Alloy 6061
Aluminium Alloy 7075
Aluminium Bronze
Amino-acid molecular crystals
Amorphous TPI - High Heat - High Flow - Lead-Free Solderable - 30% GF
Amorphous TPI - High Heat - High Flow - Transparent - Lead-Free Solderable (High Flow)
Amorphous TPI - High Heat - High Flow - Transparent - Lead-Free Solderable (Standard Flow)
Amorphous TPI - Highest Heat, Chemical Resistant, 260 ˚ C UL RTI
Amorphous TPI - Moderate Heat, Transparent
Amorphous TPI Blend - Ultra-high heat - Chemical Resistant (High Flow)
Antimonial lead (6 %)
Aramid
Aromatic peptide-nanospheres
Aromatic peptide-nanotubes
ASA - Acrylonitrile Styrene Acrylate
ASA/PC Blend - Acrylonitrile Styrene Acrylate / Polycarbonate Blend
ASA/PC Flame Retardant
ASA/PVC Blend - Acrylonitrile Styrene Acrylate / Polyvinyl Chloride Blend
Bacteriophage capsids
Beryllium
Beryllium
Bone - human cortical
Bone - spongy
Brass
Brass - Naval
Bronze
CA - Cellulose Acetate
CAB
CAB - Cellulose Acetate Butyrate
Carbon Fiber Reinforced Plastic
Carbon nitride
Carbon-fiber-reinforced plastic (CFRP) - 50/50 fibre/matrix, biaxial fabric
Cellulose Diacetate-Clareflect metallized film
Cellulose Diacetate-Colored Films
Cellulose Diacetate-Flame retardant Film
Cellulose Diacetate-Gloss Film
Cellulose Diacetate-High Slip Film
Cellulose Diacetate-Integuard Films
Cellulose Diacetate-Matt Film
Cellulose Diacetate-Pearlescent Films
Cellulose Diacetate-Semitone Films
Cellulose Diacetate-Window Patch Film (Food Grade)
Chemical Lead
Chlorinated polyether
Chlorinated PVC (CPVC)
Cobalt-chrome (CoCr)
COC - Cyclic Olefin Copolymer
Cold Drawn Wire Steel
Concrete
Concrete - High Strength (compression)
Copper
Copper (Cu) - annealed
Copper Alloy C11000 (electrolytic tough pitch)
Copper Alloy C17200 (beryllium - copper)
Copper Alloy C22000 (Commercial bronze - 90%)
Copper Alloy C26000 (cartridge brass)
Copper Alloy C36000 (free - cutting brass)
Copper Alloy C71500 (copper - nickel - 30%)
Copper Alloy C93200 (bearing bronze)
CP - Cellulose Proprionate
CPVC - Chlorinated Polyvinyl Chloride
Diamond
Diamond - synthetic
Diatom frustules - largely silicic acid
Douglas fir Wood
ECTFE
Epoxy resins
ETFE
EVA - Ethylene Vinyl Acetate
EVOH - Ethylene Vinyl Alcohol
FEP - Fluorinated Ethylene Propylene
Fiberboard - Medium Density
Flax fiber
Float glass
Glass
Glass reinforced polyester matrix
Glass-reinforced polyester (GRP)
Gold
Granite
Graphene
Grey Cast Iron
Haynes Alloy 25
HDPE - High Density Polyethylene
Hemp fiber
High-density polyethylene (HDPE)
High-strength concrete
HIPS - High Impact Polystyrene
HIPS Flame Retardant V0
Inconel 625
Invar
Ionomer (Ethylene-Methyl Acrylate Copolymer)
Iron
Kovar
LCP - Liquid Crystal Polymer
LCP Carbon Fiber-reinforced
LCP Glass Fiber-reinforced
LCP Mineral-filled
LDPE - Low Density Polyethylene
Lead - tin solder (60Sn - 40 Pb)
Lead (82Pb) - chemical
LLDPE - Linear Low Density Polyethylene
Low-density polyethylene (LDPE) - molded
MABS - Transparent Acrylonitrile Butadiene Styrene
Magnesium alloy
Magnesium metal (Mg)
Medium-density fiberboard
Medium-density fiberboard (MDF)
Molybdenum
Molybdenum - annealed
Monel
Monel 400
Mother-of-pearl (largely calcium carbonate)
Nickel
Nickel (28Ni) - commercial
Nickel 200
Nylon 66
Nylon-6
Oak Wood (along grain)
Osmium
Osmium (76Os)
Osmium nitride (OsN2)
PA 11 - (Polyamide 11) 30% Glass fiber reinforced
PA 46 - 30% Glass Fiber
PA 46 - Polyamide 46
PA 6 - Polyamide 6
PA 6-10 - Polyamide 6-10
PA 66 - 30% Glass Fiber
PA 66 - 30% Mineral filled
PA 66 - Impact Modified
PA 66 - Impact Modified, 15-30% Glass Fiber
PA 66 - Polyamide 6-6
PAI - 30% Glass Fiber
PAI - Low Friction
PAI - Polyamide-Imide
PAN - Polyacrylonitrile
PAR - Polyarylate
PARA (Polyarylamide) - 30-60% glass fiber
PBT - 30% Glass Fiber
PBT - Polybutylene Terephthalate
PC - Polycarbonate - high heat
PC (Polycarbonate) 20-40% Glass Fiber
PC (Polycarbonate) 20-40% Glass Fiber Flame Retardant
PC/PBT blend - Glass Filled
PC/PBT Blend - Polycarbonate / Polybutylene Terephthalate Blend
PCL
PCTFE
PE - Polyethylene 30% Glass Fiber
PE/TPS Blend - Polyethylene / Thermoplastic Starch
PEEK
PEEK 30% Carbon Fiber-reinforced
PEEK 30% Glass Fiber-reinforced
PEI - 30% Glass Fiber-reinforced
PEI - Mineral Filled
PEI - Polyetherimide
PEKK - Low Crystallinity Grade
PESU - Polyethersulfone
PESU 10-30% glass fiber
PET - 30/35% Glass Fiber-reinforced, Impact Modified
PET - 30% Glass Fiber-reinforced
PET - Polyethylene Terephthalate
PETG - Polyethylene Terephthalate Glycol
PFA - Perfluoroalkoxy
PGA - Polyglycolides
PHB
Phosphor Bronze
PI - Polyimide
Pine Wood (along grain)
PLA - High Heat Films
PLA - Injection molding
PLA - Polylactide
Plutonium
PMMA
PMMA (Acrylic) High Heat
PMMA (Acrylic) Impact Modified
PMP
PMP 30% Glass Fiber-reinforced
PMP Mineral Filled
Polyamide
Polyamide semi-aromatic
Polybenzoxazole
Polycarbonate (PC)
Polycarbonates
Polyethylene - LDPE (low density)
Polyethylene HDPE (high density)
Polyethylene Terephthalate - PET
Polyethylene terephthalate (PET) - unreinforced
Polyimide aromatics
Polypropylene - PP
Polypropylene (PP) - molded
Polystyrene - crystal
Polystyrene - foam
Polystyrene - PS
POM (Acetal)
POM (Acetal) Impact Modified
POM (Acetal) Low Friction
POM (Acetal) Mineral Filled
PP - 10-40% Mineral Filled
PP - 10-40% Talc Filled
PP - 30-40% Glass Fiber-reinforced
PP - Impact Modified
PP - Polypropylene 10-20% Glass Fiber
PP (Polypropylene) Copolymer
PP (Polypropylene) Homopolymer
PP Homopolymer - Long Glass Fiber, 30% Filler by Weight
PP Homopolymer - Long Glass Fiber, 40% Filler by Weight
PP Homopolymer - Long Glass Fiber, 50% Filler by Weight
PPA - 33% Glass Fiber-reinforced - High Flow
PPA - 45% Glass Fiber-reinforced
PPA - Polyphthalamide
PPE - 30% Glass Fiber-reinforced
PPE - Flame Retardant
PPE - Impact Modified
PPE - Mineral Filled
PPE - Polyphenylene Ether
PPS - 20-30% Glass Fiber-reinforced
PPS - 40% Glass Fiber-reinforced
PPS - Conductive
PPS - Glass fiber & Mineral-filled
PPS - Polyphenylene Sulfide
PPSU - Polyphenylene Sulfone
PS - High Heat
PS (Polystyrene) 30% glass fiber
PS (Polystyrene) Crystal
PSU - 30% Glass fiber-reinforced
PSU - Polysulfone
PSU Mineral Filled
PTFE
PTFE - 25% Glass Fiber-reinforced
PTFE - molded
PVC
PVC - Plasticized
PVC - Plasticized Filled
PVC (Polyvinyl Chloride) - 20% Glass Fiber-reinforced
PVC Rigid
PVDC - Polyvinylidene Chloride
PVDF - Polyvinylidene Fluoride
Rubber - small strain
SAN - 20% Glass Fiber-reinforced
SAN - Styrene Acrylonitrile
Sapphire
Silicon
Silicon - single crystal, different directions
Silicon Carbide
Silicon carbide (SiC)
Single-walled carbon nanotube
SMA - 20% Glass Fiber-reinforced
SMA - Flame Retardant V0
SMA - Styrene Maleic Anhydride
SMMA - Styrene Methyl Methacrylate
SRP - Self-reinforced Polyphenylene
Stainless Steel
Steel - A36
Steel - stainless AISI 302
Steel - Structural ASTM-A36
Stinging nettle fiber
Super Invar
Tin
Tin (Commercially pure)
Titanium (22Ti)
Titanium Alloy
Titanium alloy - Grade 5
Tool Steel
Tooth enamel
Tooth enamel - largely calcium phosphate
TPI-PEEK Blend - Ultra-high heat, Chemical Resistant, High Flow, 240C UL RTI
TPS - Injection General Purpose
TPS - Injection Water Resistant
Tungsten / Wolfram
Tungsten carbide
UHMWPE - Ultra High Molecular Weight Polyethylene
Uranium
Wood - American beech
Wood - black cherry
Wood - red maple
Wrought iron
XLPE - Crosslinked Polyethylene
Yttrium iron garnet (YIG) - polycrystalline
Yttrium iron garnet (YIG) - single-crystal
Zinc (30Zn)
Zinc (Commercially pure)
Zirconium (40Zr) - commercial
Reset
Print This
