Engineering An Illustrated Weekly Journal
Engineering, An Illustrated Weekly Journal
From July to December 1871
W.H. Maw
J. Dredge
Open: Engineering, An Illustrated Weekly Journal
Minimum Premium Membership Required
Topics and Illustrations of historical interest of the era.
- Bauschinger's Indicator Experiments on Locomotives
- Six Horse Traction Engine at the Wolverhamton Show
- Railway Bridge over The River Ohio at Louisville, USA
- Goods Wagon for the Villa Maria & Rio Cuarto Railway
- Stone Breaking Machine at Wolverhampton Show
- Wood Working Machinery
- Berrymans Water Level Regulator
- Submarine Operations at Hellgate, New York
- Horse Road Steamer
- Compound Blowing Machines
- Practical Electricity
- Warrens Street Sweeping Machine
- Compound Screw Engines
- Boilers of H.M.S. Tenedos
- Engines of the H.M.S. Tenedos
- Robinsons Band Saw
- Fisken's Steam Ploughing Tackle
- Gramme's Magneto Electric Machine
- Kirk's Refrigerating Machine
- Press for Forming Blocks of Dust Coal
- Hydraulic Pressure Crushing Mill
- Norwich Sewerage Works Boilers and Plan Pumping Station
- McEvoy's Time Fuse
- Locking Apparatus for Facing Points Railway
- Pumping Engines
- Shaft Sinking Through Water-Bearing Sand Near Homberg
- Coal Wagons
- Evan's Vertical Mill
- Dank's Rotary Puddling Furnace
- Dredging Machinery
- Piston Fitting Apparatus Used on The Kaiserin Railway
- Bennett's System of Steam Cultivation
- Gas Heated Boilers at The Tees Iron Works, Middlesbrough
- Mackie's Logo Perforator
- Swing Bridge over the River Parnitz Near Stettin
- Apparatus for Heating the Tyres by Gas at the Metropolitans Railway Works
- Gautreau's Dynametrical Governor
- Milroy's Method of Constructing Foundations
- Compound Surface Condensing Marine Engines
- Nut Tapping Machine
- Janicki's Floating Dock
- Traction Engine Wheel
- Variable Expansion Gear
- Blast Pressure Regulator for Blowing Engines
- Bessemer's Apparatus for Firing Heavy Ordnance
- Winding Engines with Automatic Variable Expansion Gear
- Register Weighting Machine
- Dank's Squeezer for Puddled Balls
- Guinotte's Expansion Gear
- Moore and Head's Hoisting Pulley
- Machinery for Bending and Flanging Plates
- Baumann's Steam Donkey Pump for Traction Engines
- Dredging Machine for the River Elbe
- Morrisons Lock for Railway Carrige Doors
- Twin Screw Engines for the Stevens Battery
- Engines for Driving Centrifugal Drying Machine
- Broadwell's Carriage for Multiple Guns
- The Mont Cenis Tunnel Air Compressing Machinery at Bardonneche
- The Hunton Governor
- Dyer's Rail Gauge
- Six Ton Shingling Hammer at the Britannia Iron Works, Middlebrough
- Vertical Engine Fairlie Engines
- Macpherson's Self Relieving Safety Valves
- Shears and Engine for Forge train at the Britannia Works, Middlebrough
- Siemans's Regenerative Furnace at the Britannia Works, Middlebrough
- Standard Rail Sections for Light Railways
- While's Blooming Mill at the Britannia Iron Works, Middlebrough
- Scrap Shears the Britannia Iron Works, Middlebrough
- Berryman's Steam Trap
- Apparatus for Measuring the Radiant intensity transmitted by Flames
- Rail Straightening Machine
- Winding Engines at the Skelton Iron Mine, Saltburn by the Sea
- Self Cleaning Corn Screen
- Hydraulic Apparatus for Lifting Railway Carriages
- High Pressure Marine Boiler
- M'Carters Condenser at the City Saw Mills, Londonderry
- Pichault's Diagrammagraphe
