Mechanical Design and Engineering Process Mechanical Engineering design is a study of design-making processes. It utilizes mathematics, the material sciences and the engineering-mechanics sciences. |
Belleville Spring Washer Equation and Calculator |
Design of Load Carrying Shaft With One Pulley & Supported by two Bearings
Journal Bearing Hydrodynamic Lubrication Analysis Equation and Calculator The primary advantage of a fluid film bearing is often thought of as the lack of contact between rotating parts and thus, infinite life. |
Design of Square Key and Keyway Equations and Calculator |
Shaft Keyway Shear and Yield Strength Requirements Formula and Calculator |
Solid Bolted Shaft Coupling Design Equations and Calculator |
Sleeve Shaft Coupling Design Equations and Calculator |
Pinned Sleeve Shaft Coupling Design Equations and Calculator |
Shaft to Shaft Axial Alignment Design Tolerances Tables Design for shaft-to-shaft alignment is the positioning of the rotational centers of two or more shafts so that the shafts are co-axial when the machine is in operation. |
The Shaft Design Book (Design Charts and Calculations for Torsional Properties of Non-Circular Shafts) Premium Membership Required |
Flywheel Effect or Polar Moment of Inertia |
Flywheel and Shaft Torque Analysis |
Internal Combustion Engine Flywheel To Drive Machine Formula and Calculator The torque (T ) delivered by an internal combustion engine is a function of the rotation angle (θ). |
Angle of Twist - Shaft Subjected to Torque Formula and Calculator This calculator will determine the angle of twist due to the applied torque on a shaft |
Solid Disk Flywheel Moment of Inertia and Shaft Stresses |
Stresses in Rotating Disks (Annular Rings) of Constant Thickness Equation and Calculator |
Two Block Shear Spring Design Equations and Calculator |
Cylindrical shear spring with axial load applied design equations and calculator, load P |
Cylindrical Torsion spring with torque applied design equations and calculator |
Retaining Snap Ring Stress and Failure Formulas and Calculator |
Retaining Snap Ring Groove Stress and Failure Formulas and Calculator |
Simple Band Brake Configuration #1 Force Equation and Calculator |
Simple Band Brake Configuration #2 Force Equation and Calculator |
Differential Band Brake Configuration #1 Force Equation and Calculator |
Differential Band Brake Configuration #2 Force Equation and Calculator |
Band Brake Design Equations |
Differential Band Brake Design Equation |
Block Brake Design Equations |
Disk Brake Design Equations |
Mechatronic Design, Devices, and Systems - Pages 486 ** Premium Membership Required ** |
Braking Torque Equation and Calculator |
Internal Drum Shoe Brake Design Equations |
Block Brake with Long Shoe Design Equations |
Clutch Disk Design Equations |
Power Transmitted by Disk Clutch Formula and Calculator |
Cone Clutch Design Equations |
Multi Plate Disk Clutch Design |
Centrifugal Clutch Design and Equations |
Fundamentals of Machine Design This practical course book has been designed and written to support the learning process in the Fundamentals of Machine Design course. Premium Membership Required. |
Double Square-Thread Power Screw Axial Linear Lifting Force Equations and Calculator |
Power Screw Turning Moment and Axial Load Formulas and Calculator Turning Moment and Axial Load are related to each other through the following equation for advance against load (or raising the load). |
Critical Speed Ball Screw and Lead Screws Formulas and Calculator |
Counterbalancing Several Masses Located in a Single Plane Formulas and Calculator |
Balancing Rotating Fixtures Turning Operations on a Lathe Formulas and Calculator |
Counterbalancing Masses Located in Two or More Planes Formulas and Calculator. Unbalanced masses or weights rotating about a common axis in two separate planes of rotation form a couple |
Fundamentals of Machine Design, Volume I, P. Orlov, 521 Pages, Premium Membership Required to view Document/Book |
Fundamentals of Machine Design, Volume II, P. Orlov, 207 Pages Premium Membership Required to view Document/Book |
Fundamentals of Machine Design, Volume III, P. Orlov, 271 Pages Premium Membership Required to view Document/Book |
Solid Rigid Shaft to Shaft Couplings Design Equations and Calculator |
Inclined Wedge Force and Friction Equation and Calculator Premium Membership Required ** |
Inclined Wedge Force and Friction Equation and Calculator Force is applied Horizontal to Wedge/Angled and Perpendicular to Horizontal Surface |
Cone Cylinder Stress and Deflection by Uniform rotation, ω rad/s, about central axis Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Forces to Pull Weight up Inclined Plane with and without Friction Equation and Calculator #3 |
Forces to Pull Weight up Inclined Plane with and without Friction Equation and Calculator #4 |
Engineering Static'sEquations and Basics |
Details of Machine Tool Design No. 14 Premium Membership Required ** |
Shaft Flat Pivot Friction Equation and Calculator |
Truncated Cone Friction Equation and Calculator |
ASME Shaft Design Allowable Stress and Diameter equations and calculators |
Lifting Boom, Davits Application and Design Equations |
Design of Rotating Shafts under Combined Loading Calculator |
Large and Small Diameter Lifting Pulley / Drum Equation and Calculator |
Two Lifting Lifting Pulley's Mechanical Advantage |
Multiple Pulley's Lifting Mechanical Advantage |
Pulley Differential Mechanical Advantage Equations |
Simple Hoist Pulley Equations |
Sling Lifting Capacity and Loading Calculator |
Cable Tension Loading Simple Calculator and Equation |
Magnetic Lifting Force Equation and Calculator |
Two Pulley Connecting Belt Design and Calculations |
Sprocket Center Distance for a Roller Chain of known Length Equation and Calculator |
Weight and Balance Equation and Calculator Trailer |
Three Gears or Pulleys Force Calculations and Equations |
Transmission Gear Ratio Equation and Calculator |
Gear Ratio Equations and Calculators - 24 separate cases |
Spur Gears Force Analysis Equation and Calculator |
Flywheel Mass, Size Design Equations and Calculator |
Static's Force Analysis for Cylinder Supported by Two Rollers Equation and Calculator |
Natural Frequency of Electric Motor Synchronous Machines Direct Connected to Reciprocating Machinery Equations and Calculator |
Handbook of Mechanical Design When Product Engineering was launched as a publication to serve the design engineers, it was obvious to the editors that a great service could be rendered to the profession by gathering and publishing data, information, and design procedures such as are contained in engineering department manuals. |
Handbook of Machine Design Components The major mission of this sourcebook is to intensify and highlight the importance of typical mechanical components by illustrating their versatility, innovative applications, history and artistry. Hopefully, this presentation will stimulate new ideas by giving the reader a graphic kaleidoscopic view of mechanical components, as well as an appreciation for their geometric grace and adaptability into complex mechanisms. |
When three bodies move relative to one another, they have three instantaneous centers, all of which lie on the same straight line. Kennedy's theorem, which states that the number of ICs, c, for a given mechanism is related to the number of links |
Modified Gruebler's Equation for Kinematics Calculator For a planar mechanism, the degree of freedom (mobility) is given by Gruebler's Equation: |
Scissor Jack Design Calculation Equation |
Mathematical Analysis of Actuator Forces in a Scissor Lift |
Scissor Lift Design and Analysis Equations, Mathematical Analysis of Scissor Lifts |
Screw Gear Axial Force Calculation |
Power Screw Design Equations and Calculator |
Ball Screw Design Equations and Selection Criteria: |
Power Screw Buckling and Deflection Equations and Calculator |
Vehicle Forces Equations and Calculator |
Rolling Resistance Equation and Calculator |
Tire Traction Breakaway Equation and Calculator |
Tire Traction Force Equation and Calculator |
Mechanisms in Modern Engineering Design - A Handbook for Engineers, Designers, and Inventors Premium Membership Required |
Watt Governor Isochronous Speed Equation |
Screw jack application equations andcalculator |
Porter Governor Isochronous Speed Equation |
Hartnell Governor Isochronous Speed Equation |
Simple Mechanical Levers Equations and Calculators
Simple lever with multiple weights outside fulcrum equations and calculators. |
Adding Forces by the Parallelogram Resultant of Two Forces Equation and Calculator |
Loaded Ring Bolt Resultant Loading |
Toggle Mechanism Pivot Center Load Design Formula and Calculator |
Toggle Mechanism Handle and Link Clamp #2 Formula and Calculator |
Toggle Mechanism Handle and Link Clamp Formula and Calculator |
Toggle Mechanism Triangle Arm and Link Formula and Calculator |
Manufacturing Toggle Mechanism Ninety Degree Pivot Lock Formula and Calculator |
Toggle Clamp Equal Length Arms Equations and Calculator A link mechanism commonly known as a toggle joint is applied to machines of different types, such as drawing and embossing presses, stone crushers, etc., for securing great pressure. The principle of the toggle joint is shown by Fig. 1. |
Manufacturing Toggle Mechanism Center Locking Design Formula and Calculator |
Manufacturing Toggle Mechanism Spring Loaded Ninety Degree Design Formula and Calculator |
Vector Finding Two Concurrent Components of a Single Force Equation and Calculator, Case 1 |
Finding Two Vector Concurrent Components of a Single Force Equation and Calculator, Case 2 |
V-Belt Angle Between Two Sheave |
V-Belts Design Requirements Equations and Calculator |
Length of Belt Traversing Three Pulleys |
Theoretical Mechanics, Kinematics, Dynamics and Static's Premium Membership Required to view Document/Book |
Air Resistance Force to Vehicle Forward Motion Equation and Calculator |
Vehicle Speed on basis of engine rpm, tire size and gear ratios equations and calculator |
Distance traveled on uphill or downhill gradients Equation and Calculator |
Gradability and Traction Equation and Calculator |
Vehicle Hill Climbing Gradability taking into Account Road Tire Adhesion Equation and Calculator |
Power Take-Off (PTO) on Transfer Case Rotational Speed Per Distance Traveled (meter) Equations and Calculators |
Vehicle Turning Circle Design and Engineering Equations and Calculators |
Truck and Car Axle Load Equations |
Trailer Hitch Ball Coupler Size Equations and Calculators |
Rigid Drawbar Trailers / Central Axle Trailers Loading Equations and Calculators |
Fifth Wheel Coupling Loading Equations and Calculators |
Geneva Mechanism External Design Calculator and Equations |
Geneva Internal Mechanism Design Equations and Calculator |
Pivot Arm Toggle Formulae and Calculator |
Work Holding Clamping Toggle Mechanisms Calculations |
Triangular Clamping Toggle Mechanism Design Formula and Calculator |
Toggle Mechanism Clamping Ninety Degree Reaction Points Design Formula and Calculator |
Scotch Yoke Mechanism Design Equations and Calculator |
Scotch Yoke Mechanism Design, 48 Pages An experienced mechanical engineer was asked to design a smooth reliable drive to oscillate a long slender induction coil gently and continuously. The coil serves as a precision control element in a large linear accelerator. Part A of the case consists of an account of the first and second designs. Part B is a brief account of a difficulty which occurred several months later. An Instructor's Note is included. |
Tangent Cotangent Mechanism Design Equations and Calculator |
Roller Detent Mechanism Design Equations and Calculator |
Plunger Detent Mechanism Design Equations and Calculator |
Wiper Mechanism Design and Simulation Simulator for a 4-bar wiper mechanism with motion analysis and UI for user to change parameters. |
Piston Slider Crank Mechanism Design Equations and Calculator |
Machine Design (S.I. Units), R.S. KHURMI, 1251 pages |
Mechanical Design Handbook, Peter R. N. Childs, 373 pages |
Bolt Pattern Group Pullout Excel Spreadsheet Calculator, Spreadsheet Calculator Calculated per the AISC Ninth Edition |
Dowel Pin Design Length Shear Stress and Contact Pressure Check Equations and Calculator |
Balancing Rotating Fixtures For Turning Operations on a Lathe Formulas and Calculator Manufacturing fixtures rotating at a high speed require balancing. Often it is assumed that the center of gravity of the work piece and fixture and of the counterbalancing masses are in the same plane; however, this is not usually the case. Counterbalancing masses are required in two separate planes to prevent excessive vibration or bearing loads at high speeds. |
Pelton Impulse Water Turbine Design Formulas This is a water turbine in which the pressure energy of the water is converted wholly to kinetic energy in one or more jets which impinge on buckets disposed around the periphery of a wheel. |
Stresses in Universal Knuckle Joint Formulas and Calculator: Universal joints are a mechanical form of coupling, originally known as a Cardan or Hooke's coupling, is used for connecting two shafts the axes of which are not in line with each other, but which merely intersect at a point. |
Flat Belt Drive Design Calculator and Equations Flat belts have high strength, can be used for large speed ratios (>8:1), have a low pulley cost, produce low noise levels, and are good at absorbing torsional vibration. |
Stresses Due to Press Fit Bushings into Lug or Ring Calculator and Equations Pressure between a lug and bushing assembly having negative clearance can be determined from consideration of the radial displacements. |
