Structural Shapes Steel, Aluminum ASTM, BS, EN, ISO Sizes Tables - Engineers Edge
Structural Materials Menu
Engineering Materials Menu
- The following are to links to Structural Shapes Steel, Aluminum ASTM, BS, EN, ISO, GOST Sizes Tables .
- Should you find any errors omissions broken links, please let us know - Feedback
- Do you want to contribute to this section? See Premium Publisher Program
** Search this PAGE ONLY, click on Magnifying Glass **
- Structural Steel AISC Shapes Properties Viewer
- Polar Area Moment of Inertia
- Strength of Materials and Applications
- Young's Modulus
General Structural Design
ASTM, ANSI, ASME Structural Shape Sizes
- AISC Ultimate Structural Shapes Properties Viewer
- American Standard Aluminum Channel Sizes Table
- Aluminum Channel Table Aluminum Association Standard
- Standard Channels per. Aluminum Association Standard Dimensions, Areas, Weights and Section Properties
- Standard Aluminum Angle Equal Leg Aluminum)
- Standard Aluminum Channel, Standard Aluminum
- Aluminum B308 Aluminum Structural Shape Anlge Unequal Legs
- Aluminum I-Beam Dimensional Sizes, Area Moment of Inertia Table - Aluminum Association Standard I-Beam Dimensions, Areas, Weights and Section Properties
- AISC, ASTM Channel Steel
- AISC, ASTM Wide Flange #1 Steel
- AISC, ASTM Wide Flange #2 Steel
- AISC, ASTM S Narrow Flange I Beam Steel
- AISC, ASTM Angle Steel #1
- AISC, ASTM Angle Steel #2
- AISC, ASTM Angle Unequal Leg Aluminum
- Standard Aluminum I-Beams Aluminum
- AISC, ASTM Steel Angle Unequal Leg Steel
- AISC, ASTM Structural Tees Cut from W Flange
BS, EN, ISO, BSI Structural Shape Sizes
- AISC, ASTM S Flange (Steel)
- Steel Section Properties Chart Narrow I-Beam BS 4-1 | EN 1993-1-1
- Steel Section Properties Chart Wide I-Beam BS 4-1 | EN 1993-1-1
- Structural Steel Angle Section Properties, Unequal Leg BSI BS EN 10056
- Structural Steel Angle Section Properties, Equal Leg BSI BS EN 10056
- Structural Steel I-Beam Universal Flange Section Properties BS 4-1:2005
- Structural Steel I-Beam Universal Flange Section Properties BS4: Part 1: 1993
- Circular Hollow Tube Sections Cold-Formed per BS EN 10365 Euro Code 3 Section Properties Calculator
- Elliptical Hollow Tube Section Properties Calculator
- EN Equal Leg L Section per. EN 10056-1
- EN Channel UPE, PFC and UPN per. EN 10365
- IPN and J Taper I Flange Sections Dimensions, Engineering Data and Masses per. EN 10365
- UC Parallel Flange Sections per. EN 10365
- UB Wide Flange Bearing Piles per. EN 10365
- UBP Wide Flange Bearing Piles per. EN 10365
- HP Wide Flange Bearing Piles Dimensions, Engineering Data and Masses per. EN 10365
- HD Wide Flange Columns Dimensions per. EN 10365
- HL & HLZ Extra Wide Flange Engineering Data and Masses per. EN 10365
- HE Wide Flange I Section Dimensions, Engineering Data and Masses per. EN 10365
- Parallel Taper Flange Channels per. EN 10365 Calculator
- Parallel Flange I Section per. EN 10365
- Rectangular Hollow Tube Section Properties Calculator
- Rectangular Tube Sections Cold-Formed per BS EN 10219-2 Section Properties Calculator
- Square Hollow Tube Hot-Finished Section Properties Calculator per. BS EN 10219-2
- Square Universal Hollow Tube Sections Hot-Finished per BS EN 10365 Euro Code 3 Section Properties Calculator
- Circular Hollow Tube Universal Section Properties Calculator
- Universal Tees (T) Split from UC per BS EN 10365 Euro Code 3 Section Properties Calculator
- Universal Tees (T) Split from Universal Beams Calculator
- Universal Back to Back Unequal L Angles (L) Section Properties Calculator
- Universal Back to Back Equal L Section Properties Calculator
- Universal Unequal leg Angles (L) per. BS EN 10365 Euro Code 3 Section Properties Calculator
- Universal Equal leg Angles (L) per. BS EN 10365 Euro Code 3 Section Properties Calculator
- Universal Parallel Flange Channels Properties Calculator
- Universal Narrow Beams Engineering Data Calculator
- Universal Columns Section Properties Calculator
- Universal Bearing Piles Section Properties Calculator
Indian Standards Per. IS 808
SST ASIC Structural Shapes
AISC SST Tube Design & Dimensional Data
GOST Standard Structural Shapes
Properties of Rolled-Steel L Shapes, Angles with Equal Legs. Standard GOST 8509-72
