Civil Engineering Design Knowledge and Resources
- The following are to links to civil engineering resources, tools, articles and other useful data.
- Should you find any errors omissions broken links, please let us know - Feedback
** Search this PAGE ONLY, click on Magnifying Glass **
General Civil Engineering
- AASHTO LRFD Bridge Slab Design Calculator Spreadsheet - This spreadsheet was created to aid in the rapid design and/or checking of Bridge Decks or Reinforced Concrete Boxes in accordance with AASHTO 2004 LRFD.
- Acoustic Sound Pressure Level Chart Sound pressure is the local pressure deviation from the ambient (average, or equilibrium) atmospheric pressure, caused by a sound wave.
- Acoustic Loudness Sones Reference Table System Design Guidelines for Room Loudness.
- Acoustic System Design Equations Sound Power (W) - the amount of power a source converts to sound in watts.
- Airblast Shock Wave Equation and Calculator
- Allowable Stress Design Equations and Calculator
- Bazin Formula for Weirs Formula and Calculator
- ASTM C14 Concrete Sewer Pipe Dimensions and Weights
- ASTM C76 Reinforced Concrete Sewer Pipe Dimensions and Weights
- Capillary Number and Pressure Formulas and Calculators
- Catenary Curve Calculator and Expanded Excel Design Equation and Calculator
- Concrete Long Term Creep Deflections per. ACI 318 Equations
- Concrete Modulus of Elasticity Equations and Calculator
- Concrete Modulus of Rupture Equations and Calculator
- Concrete Splitting Tensile Strength Test Equations and Calculator
- Converting Sound Power to Sound Pressure Formulas and Calculator - Designers are often required to use sound power level information of a source to predict the sound pressure level at a given location.
- Characteristic Time for Linear Diffusion in Reservoirs Formulas and Calculator
- Culvert Inlet Outlet Safety Barriers and Grates Head Loss Calculator
- Activated Sludge Wastewater Treatment Plants In conventional (plug-flow) activated sludge plant, the primary-treated wastewater and acclimated micro-organisms (activated sludge or biomass) are aerated in a basin or tank. Premium Membership Required
- Adhesive Joints in Timber Engineering - Modeling and Testing of Fracture Properties
- Area Development Planning (ADP) for Land and Buildings The process that is commonly used in developing new project sites. Premium Membership Required
- Average Permeability for Linear flow - Series beds Formula and Calculator
- Basic House Building Structure Components and Terminology illustration represents some basic structural component use in the construction of a residential or other structure.
- Basement Wall Design Spreadsheet Calculator per. EN 1992-1: 2004
- Brad Nails Standard Size and Length
- Bridge Concrete Slab Design Spreadsheet Calculator
- Commercial Lumber Sizes Standard reference and size data for commercially available lumber within the USA. All data is in imperial units (Inches).
- Asphalt and Concrete Pavement Recycling guidance for preparing plans and specifications and for ensuring the quality of recycled bituminous concrete. Premium Membership Required
- Capacity Calculations of Structural Members Spreadsheet Calculator
- Civil Engineering Formulas Premium Membership Required to view Document/Book
- Building Stones Clays, A Handbook for Architects and Engineers, Premium Membership Required to view Document/Book
- Dam’s Spillway (overflow spillway) Flow Formula and Calculator
- Design of Double Glass according to Canadian Code CAN/CGSB-12.20-M89 Spreadsheet Calculator
- Dimensions of Ductile Iron Pipe Special Pressure Classes (customary U.S. units)
- Discharge Rate From Pressurized Tank Equations and Calculator
- Eductor Pump Design Equations
- Engineering Properties of Typical Rock Types
- Wood Structural Design Effective Length for Bending Members Formula and Calculator
- Excavation Removal Capacity Volume Rates vs Methods
- Flow over Channel Rise Hump Formula
- Fractional Flow Curve Formulas and Calculator
- Fteley and Streans Formula and Calculator
- Greenhouse Gases: Global Warming Potential
- Hooghoudt's Drainage Rate Equation and Calculator
- Ventilation Duct Stack Pressure Review, Formulas and Calculator Duct stack pressure is the hydrostatic pressure caused by the weight of a column of air located inside or outside a building.
- Electrostatic Precipitator Efficiency Calculator
- Engineering Properties for Wood #1
- Engineering Properties for Wood #2
- Engineering Properties for Wood #3
- Fastener Design Engineering Manual - Premium Membership Required
- Euro Steel Beam Load and Rest on Bottom Flange Spreadsheet Calculator
- Flow Through a Sluice Gate Formula and Calculator
- Flow Velocity in Straight Sewers Formula and Calculator
- Fundamentals of Surveying Theory and Samples
- Gravity Sewer Pipe (solid wall) Table Dimensions and Sizes
- Wood Column Stability Factor Formulas and Calculator
- Column Load Take Down and Design for Rectangular Columns to EN 1992: 2004
- Coulomb Active Earth Pressure Spreadsheet Calculator
- Common Nails Required for Rafter Ceiling Joist Heel Joint Connections Industry standard nail size data chart for rafter ceiling joist and heel.
- Compressibility of a Fluid Equations and Calculator
- Concrete Slab Volume Estimator Calculator Estimate the require concrete volume to fill the width, height and depth given.
- Concrete Footer Volume Estimator Calculator Calculate required concrete volume to fill footing data given.
- Concrete Column Volume Estimator Calculator Estimate the required concrete to fill the quantity, height and diameter of concrete columns.
- Concrete Rectangular Beam Section Analysis Calculator Concrete Rectangular Beam Section Analysis Calculator Beam or One-Way Type Shear per Per ACI 318-05 Code
- Concrete Structural Designers Guide, High Performance Premium Membership Required
- Continuous Beams Design Spreadsheet Calculator per. BS EN 1992-1: 2004
- CSA Beam Column Design Spreadsheet Calculator
- Curved Beam Stress and Deflection Design Spreadsheet Calculator
- Cylindrical Column Design Spreadsheet Calculator per. E1992-1 : 2004
- Density of Wood as Function of Moisture Content Equation and Calculator
- Wood Maximum Dowel Bearing Strengths, for Dowel-Type Fasteseners Calculator
- Estimated Seasonal Efficiencies and Annual Costs of Heating Systems
- Flexural Strengthening of Reinforced Concrete Beam with FRP Laminates Spreadsheet Calculator
- Head Changes Caused by Pipe Size Enlargement Formula and Calculator
- Head Changes Caused by Pipe Size Sudden Reduction Formula and Calculator
- Heat Loss From House or Building
- Holding Power of Wood Screws The results of tests of the holding power of over 10,000 wood screws inserted in the side and end grain of seven kinds of wood.
- Honeycomb Beam & Panel Calculations Spreadsheet Calculator
- Lag Screws in Wood Pullout Withdraw Resistance Force Formulae and Calculator. Lag screws are commonly used because of their convenience, particularly where it would be difficult to fasten a bolt or where a nut on the surface would be objectionable.
- Lag Screw Wood Withdrawal Force Formula and Calculator per. AWC-NDS
- Load Bearing Walls Review & Design Load-bearing wall (or bearing wall) is a wall that bears a load resting upon it by conducting its weight to a foundation structure.
- Pavement and Road Design For Seasonal Frost Conditions Procedures for the design and construction of pavements placed on subgrade or base course materials subject to seasonal frost action.
- Lift From Rotating Cylinder Formula
- Load Analysis of Building (Análisis de carga de la Construcción) Spreadsheet Calculator
- Design Laterally Loaded Elastic Piles Spreadsheet Calculator
- Allowable Loads on Piles Formula and Calculator A dynamic formula extensively used in the United States to determine the allowable static load on a pile is the Engineering News formula.
- Engineering Properties of Visually Graded Structural Lumber Douglas-Fir-Larch, Hem-Fir, Spruce-Pine-Fir
- Engineering Properties of Visually Graded Southern Pine Lumber. Lumber Visually Graded Dimension, Engineering Design Properties - Engineering design values are for normal load duration and dry service conditions
- Mechanical Engineers Pocket Book Premium Membership Required to view Document/Book
- Natural Stones Physical and Thermal Properties
- Pile Capacity From Driving Data Equations and Calculator
- Plywood Minimum Bend Radius Design Practices. Plywood, after softening, may be bent on a cold ventilated form.
- Machinability of Wood
- Monolithic Corbels and Brackets According To ACI 318 - 99 Spreadsheet Calculator
- Moving Loads on Bridge Graphical Calculator Spreadsheet
- Nominal Axial Compressive Strength Non-prestressed Concrete Columns per. ACI 318-14 American Concrete Institute (ACI) Formulas and Calculator
- Odor Control and Odor Thresholds for Human Smell Ventilation engineering:
- Padstone Structural Analysis EU Standards Calculator Spreadsheet
- Photogrammetry Calculations & Review Photogrammetry is the art and science of obtaining reliable measurements by photography (metric photogrammetry) and qualitative evaluation of image data (photo interpretation).
- Wood Pressed Drift Pins / Bolts Pullout Withdraw Resistance Force Formulae and Calculator. A drift bolt (or drift pin) is a long pin of iron or steel, with or without head or point. It is driven into a bored hole through one timber and into an adjacent one, to prevent the separation of the timbers connected and to transmit lateral load.
- Proportional Weirs Equations and Calculator
- Purlin Roof Structure Review A purlin (or purline) is a horizontal structural member in a roof.
- Wind Driven Rain Load Review, Equation and Calculator - The load from rain, especially wind-driven rain, is the main reason for moisture-related building failure.
- Reinforced Concrete Beam Design per. ACI 318-08 Calculator Spreadsheet
- Reinforcing Rebar Engineering Data Rebar (short for reinforcing bar ), also known as reinforcing steel , reinforcement steel and colloquially in Australia as reo
- Minimum Reinforcement Steel Area per. ACI 318 Equations and Calculator
- Osmotic Pressure Equation
- Oxygen Solubility at Barometric Pressure Calculator, Formula nd Calculator
- RC Shear Wall Analysis and Design Spreadsheet Calculator
- Required Flow Velocity in Sewers Formula and Calculator
- Hydraulic Scissor Lift Design Project
- Screws Fastener in Particle Board Maximum Torque and Pullout Withdraw Resistance Force Formulae and Calculator Tapping screws are commonly used in particle board where withdrawal strength is important. Care must be taken when tightening screws in particle board to avoid stripping the threads.
- Seismic Design of Steel Structures Canadian Spreadsheet Calculator
- Seismic Loads for Liquid Containing Rectangular RC Tank According ACI 350 306 Spreadsheet Calculator
- Settlement Under Foundations Calculations Approximate relationship between loads on foundations and settlement is:
- Shear Wall Design & Review A shear wall is a wall composed of braced panels (also known as shear panels) to counter the effects of lateral load acting on a structure.
- Siphon Flow and Discharge Rates Tables and Charts
- Siphon Flow Rate from Small Pipes Equation and Calculator
- Siphon Discharge Rate Equations and Calculator
- Singly Reinforced Rectangular Section Flexural Design According to ACI 318-02 Spreadsheet Calculator
- Soil & Slope Stability Analysis
- Soil Cohesion Values Table Typical soil cohesion values for different soils
- Specific Weight Review and Formula
- Specific Gravity for a Solids Slurry Formula and Calculator
- Speed of Sound in Various Fluids, Liquids and Solids.
- Speed of Sound in a Liquid or Fluid Formula
- Standard Nail Sizes Engineering Table Box nail size identification chart and nail types,
- Steady-State Indoor Air Quality Concentrations, Review, Formulas and Calculator,
- Storm Land Drain Pipe Sizing Formula and Calculator
- Structural Bearings and Expansion Joints Premium membership required
- Structural Lumber Engineering Properties Structural Lumber Wood Engineering Properties. Modulus of Elasticity of Wood, Wood Engineering Design Data.
- Structural Engineers Handbook Premium Membership Required to view Document/Book
- Shear Strengthening of T-beam with FRP Spreadsheet Calculator
Structural Lumber Engineering Properties 5" to 5" Thick and Wider Structural lumber engineering properties for sizes 5' x 5'. Data includes lumber grade, fiber stress, tension in parallel compression ratings, and modulus of elasticity.
- Time to Establish Flow in Pipeline
- Theoretical Pile Point-Bearing Capacity Equations and Calculator
- Properties of Structural Wood - Specific Gravity and Weight of Wood
- Switch Stand Loading (Wind and Seismic) Spreadsheet Calculator
- Symmetrically Reinforced Rectangular Column Design, Bent About Two Axis Spreadsheet Calculator per. 1992-1 : 2004
- Slip-critical Connection With Long-slotted Connection Spreadsheet Calculator
- Structural Shapes Moment Connections Design Spreadsheet Calculator
- Thermal Conductivity of Soils and Rocks
- Time to Empty Tank Formula and Calculator
- T-Beam Design Spreadsheet Calculator
- Torsion in Thin-Walled Noncircular Shells Formulas and Calculator
- Traffic Signal Timing Calculator
- Transmission Line Single Pole Analysis Spreadsheet Calculator
- Shear Center for Beams Equations and Calculator
- Subframe Analysis Spreadsheet Calculator per. BS EN 1992-1: 2004
- Thermal Properties of Common Building Materials
- Ultimate Strength Design Method
- Circular Hollow Tube Sections Cold-Formed per BS EN 10365 Euro Code 3 Section Properties Calculator
- Elliptical Hollow Tube Section Properties Calculator
- Rectangular Hollow Tube Section Properties Calculator
- Rectangular Tube Sections Cold-Formed per BS EN 10219-2 Section Properties Calculator
- Square Universal Hollow Tube Sections Hot-Finished per BS EN 10365 Euro Code 3 Section Properties Calculator
- Circular Hollow Tube Universal Section Properties Calculator
- Square Hollow Tube Hot-Finished Section Properties Calculator per. BS EN 10219-2
- Universal Tees (T) Split from UC per BS EN 10365 Euro Code 3 Section Properties Calculator
- Universal Tees (T) Split from Universal Beams Calculator
- Universal Back to Back Unequal L Angles (L) Section Properties Calculator
- Universal Back to Back Equal L Section Properties Calculator
- Universal Unequal leg Angles (L) per. BS EN 10365 Euro Code 3 Section Properties Calculator
- Universal Equal leg Angles (L) per. BS EN 10365 Euro Code 3 Section Properties Calculator
- Universal Parallel Flange Channels Properties Calculator
- Universal Narrow Beams Engineering Data Calculator
- Universal Columns Section Properties Calculator
- Universal Bearing Piles Section Properties Calculator
- Wood Strength and Related Engineering Design Properties
- Wood Screw Pullout Withdraw Resistance Force Formulae and Calculator
- Wood Glue Joint Bevel Surfaces Strength Formulae and Calculator Wood Adhesive tapered angle joint equations for stress in tension, stress in shear, tensile stress in brazed joint.
- Bolts and Screws Design Rules for Wood Installation, Allowable Loads and Stress in Wood with Fastener, Screw Spacing in Wood , Allowable Loads and Stress in Wood with Fastener - Wood Post-1991 Equations and Calculator
- Storm Drain Pipe Sizing Formula and Calculator
- Ultimate Strength Design Method Calculator
- Viscosity Grade Table ISO 3448
- Weir Flow Rectangular Open Channel Water Flow Calculator and Formula
- Water Flow Kinetic Force in Flow Around Submerged Object Calculator and Equation.
- Wood Butt (End to End) Joint Glue Adhesive Strength Equations and Calculator
- Wood Lap Joint Glue Adhesive Strength Design Equations and Calculator
- Wood Dowel Pin Shear Stress and Contact Pressure Check Equations and Calculator
- Wood Shear Stress Design Formulas and Calculator
Hydraulic Design
- Hydraulic Jump Conjugate Depths Equations and Calculator
- Hydrostatic Pressure Force of a Fluid On Vessel Planes Equations The hydrostatic force of pressure F is that force which is exerted on the wall by the fluid only - i.e. without consideration of pressure p0.
- Hydrostatic Discharge of Liquid From Vessel Bottom Equations and Calculator
- Vessel With Pressure Applied to Liquid Level Equations and Calculator
- Rainfall Intensity and Peak Storm Water Runoff Rate Equations and Calculator Rainfall Intensity and Peak Storm Water Runoff Rate for proper design of drainage requirements.
- Pressure on Submerged Curved Surfaces Equation Hydrostatic pressure on a submerged curved surface
- Fluid Flow Open Channel Calculator calculator uses Chezy and Manning's equation to determine the wetted perimeter, hydraulic radius, flow area, Chezy coefficient and flow velocity.
- Head loss in a Pipe Calculator Head loss in a Pipe (Darcy - Weisback Equation)
- Industrial Wastewater Collection and Treatment
- Rainfall Runoff Rate On Minor Size Land Formulas and Calculator
- Storm Drains Junction Losses Calculation For adjoining pipes to be considered a pipe junction, the node and only two inflow pipes (a lateral and a trunk) may enter the junction.
- Pipe Exit Loss Equation The exit loss, ho, is a function of the change in velocity at the outlet of the pipe as
- Water Supply Treatment Plant Design Spreadsheet Calculator
- Air Flow Through Opening Caused by Wind Only Calculator
- AISC Base Plate for Compression Spreadsheet Calculator
- AC Substation Grounding Requirements Calculator Spreadsheet Premium Membership required
- Analysis and Design of Concrete T-Beams Spreadsheet Calculator
- Beam Three Support Two Loads Moments, Shear and Reactions Equations and Calculator
- Beam Three Support Four Loads, Moments, Shear and Reactions Equations and Calculator Continuous beam of two equal spans - four concentrated loads, P, at third points of each span Calculator
- Beam Three Supports Uniform Load, Moments, Shear, Reactions and Deflections Equations and Calculator
- Beam Three Supports Uniform Load between two supports, Moments, Shear and Reactions Equations and Calculator
- Beam Three Supports Concentrated Load between two supports, Moments, Shear and Reactions Equations and Calculator.
- Beam Three Supports Concentrated Load Location Defined between two supports, Moments, Shear and Reactions Equations and Calculator.
- Beam Four Supports with Three Concentrated Loads Applied Supports, Moments, Shear and Reactions Equations and Calculator
- Beam Four Supports with Six Concentrated Loads Applied Supports, Moments, Shear and Reactions Equations and Calculator
- Baseplate with Large Moment to AISC LRFD Spreadsheet Calculator
- Bearing Capacity of Soils ultimate bearing capacity under a long footing at the surface of a soil is given by Prandtl's equation:
- Bearing Capacity of Soils Analysis and Review Design Document
- C Purlins Design Spreadsheet Calculator
- Circular Mander Concrete Stress-Strain Section Calculator
- Circular Composite Beams and Columns Design Spreadsheet Calculator
- Cement Engineers Handbook Premium Membership Required to view Document/Book
- Column Stress for Buildings AISC specification for allowable-stress design (ASD) for buildings provides two formulas for computing allowable compressive stress
- Cantilever Concrete Slab Design per IS 456:2000 Spreadsheet Calculator
- Composite Rectangular Beam and Columns Spreadsheet Calculator
- Concrete Anchor Pullout Tension Design Calculator Concrete Anchor subjected to Tension Pullout Force per ACI 318-02.
Concrete Anchor Group Pullout Tension Design Calculator Concrete Anchor Tension Pullout Force Design Calculator per ACI 318-02.
- Concrete Anchor in Tension and Shear Near Edge Concrete Anchor Tension Pullout Force Design Calculator per ACI 318-02.
- Concrete Anchor Group Tension and Shear Fasteners Near Two Edges Based on ACI 318-02 Calculator Anchor Group Tension and Shear Fasteners Near Two Edges Based on ACI 318-02
- Concrete Anchor Group Tension and Shear Fasteners Near Two Edges Based on ACI 318-02 Calculator Case # 5 Anchor Group Tension and Shear Fasteners Near Two Edges Based on ACI 318-02
- Concrete Column Base Plate Design Base plates are usually used to distribute column loads over a large area.
- Concrete Floor Slabs Design Requirements and Equation Floor slabs on grade should be analyzed for adequate structural live loads.
- Concrete Foundation Anchor Bolts Design and Selection Anchor bolt is used to attach objects or structures to concrete.
- Concrete Pad Foundation Design Spreadsheet Calculator
- Concrete Reinforced Beam Design to BS8110 Calculator
- Concrete Creep, Shrinkage Factors and Tensile Strength Calculation per. BS EN 1992
- Concrete Slab on Grade according to New Zealand Standards Spreadsheet Calculator
- Cooling Tower Water Treatment Premium Membership Required
- Core Shear Wall Design Spreadsheet Calculator per. EN 1992-1: 2004
- Design Guide Structural Stainless Steel
- Diesel Electric Generating Plants - Premium Membership Required
- Engineering Properties of Lumber / Wood
- Equal Spacing Formulas and Calculator In the fabrication of wood or structural steel component spacing may be required and determined by the fabricator.
- Fixed Steel Column Base Design Calculator
- Flagpole Base Design Calculator Flagpole Base Design requirements per IBC and UBC
- Flat Concrete Slab Design Spreadsheet Calculator per. BS EN 1992-1: 2004
- Flexural Crack Width in Concrete Calculator per. BS EN 1992-1: 2004
- Foundation Design for Building and Structures
- Manual of Concrete Design, ACI
- One-way Slab Design Spreadsheet per. BS EN 1992-1: 2004
- One-Way Slab Design Rigorous Spreadsheet per. BS EN 1992-1: 2004
- Retaining Wall Concrete Design Spreadsheet Calculator per. EN 1992-1: 2004
- Parshall Flume Flow Measurement Equations and Calculator
- Pile Cap Design Spreadsheet to Eurocode Spreadsheet Calculator per. EN 1992-1: 2004
- Pressure Distribution of a Fluid within a Vessel Equations and Calculator
- Standard ReBar Shapes Formula and Calculators Premium Membership Required
- Rectangular Concrete Beam Section Analysis Beam Torsion and Shear Rectangular Concrete Beam Section Torsion and Shear Per ACI 318-05 Code
- Rectangular Concrete Beam Section Analysis Crack Control - Distribution of Flexural Reinforcing Flexure, Shear, Crack Control, and Inertia for Singly or Doubly Reinforced Sections Per ACI 318-05 Code
- Rectangular Concrete Beam and Slab Section Analysis Crack Control, and Inertia for Singly or Doubly Reinforced Sections Per ACI 318-05 Code
- Rectangular Mander Concrete Stress-Strain Section Calculator
- Reinforced Concrete Analysis and Design for Torsion Spreadsheet Calculator
- Reinforced RC Beam / Slab with FRP Plates Analysis and Design for Torsion Spreadsheet Calculator
- Retaining Wall & Excavation Support Design and Analysis Forces include earth pressures, seepage and uplift pressures, surcharge loads, and weight of the wall.
- Reinforced Concrete Element Design Spreadsheet Calculator per. EN 1992-1: 2004
- Reinforced Concrete Elements Design and Analysis Spreadsheet Calculator
- Reinforced Concrete Handbook, for Engineers, Architects, and Contractors Premium Membership Required to view Document/Book
- Load & Resistance Factor Design for Shear in Buildings American Institute of Steel Construction (AISC)specifications for load-and-resistance factor design (LRFD)for buildings.
- Shear Wall Analysis and Design Excel Spreadsheet Calculator Note: Accessing this resource requires an active Premium Membership with Engineers Edge
- Slab Punching Shear Calculation Spreadsheet Calculator
- Slab Canopy Design Spreadsheet Calculator
- Slope Deflection Method Método de Deflexión Pendiente Spreadsheets Calculator
- Soil Compaction Testing Core Method sand-cone method is used to determine in the field the density of compacted soils in earth
- Soil Permeability Review The coefficient of permeability k is a measure of the rate of flow of water through saturated soil under a given hydraulic gradient
- Soil Settlement Under Foundations For the purpose of wind or earthquake engineering, columns may be designed to resist lateral forces.
- Soil, Stress Conditions Analysis Stress conditions in soils at a point, stresses beneath structures and embankments
- Soils and Foundations, Reference Manual Vol. I
- Soils and Foundations Reference Manual Vol. IINaresh C. Samtani*, PE, PhD, Edward A. Nowatzki*, PE, PhD
- Stair Flight & Landing Design Spreadsheet Calculator per. EN 1992-1: 2004
- Staircase Analysis and Design Spreadsheet Calculator
- Stream Power Formulas and Calculator Stream power is a geomorphology concept that is a measure of the available energy a stream has for moving sediment, rock, or woody material.
- Strap Footing Design Spreadsheet Calculator
- Structural Column Base Plate Columns are frequently used to support beams or arches on which the upper parts of walls or ceilings rest.
- Structural Load Bearing Plates To resist a beam reaction, the minimum bearing length N in the direction of the beam span for a bearing plate is determined by equations.
- Structural Design Criteria for Buildings Criteria for the design of buildings using cast-in-place or precast construction with plain, reinforced, or prestressed concrete.
- Structural Rectangular Spread Footing Analysis calculator will analysis the rigid rectangular spread footings with up to 8 total piers
- Welding Splice Design of Beam Spreadsheet Calculator
- Tension and Shear In A Slip-critical Connection Spreadsheet Calculator
- Topographic Wind Factor (Kzt) according to ASCE 7-10 Spreadsheet Calculator
- Trapezoidal Weirs Flow Formula and Calculator
- Triangular Weirs Flow Formula and Calculator
- Thrust block Excel Spreadsheet Calculators
- Wind Force on Flag Pole Cylinder Formula and Calculator (Airflow around a Cylinder Formula)
- Wind Loading on Fences and Hoarding's Premium membership required.
- Computational for Design Wind Pressure as per UBC 1997
- Wind Loads on vertical Walls Equation
- Wind Loads on Partially Open Building ASCE 7-10 Spreadsheet Calculator
- Wind Loading Analysis MWFRS & Clad WIND LOADING ANALYSIS - MWFRS and Components/Cladding Per ASCE 7-02
- Wind Loading Analysis per ASCE 7-98 Main Wind-Force Resisting System Per ASCE 7-98 Code for Low-Rise Buildings
- Wind Loading Analysis For Low Rise Building Per ASCE 7-05 Code for Enclosed or Partially Enclosed Buildings Using Method 2: Analytical Procedure (Section 6.5) for Low-Rise Buildings
Wind Loading Analysis Main Force Resisting System Excel
Per ASCE 7-05 Code Method 2 for Enclosed or Partially Enclosed Buildings
Design Wind Load Case 2 from Figure 6-9 -
Wind Loading Analysis Main Force Resisting System Excel Calculator Spreadsheet
Design Wind Load Case 4 from Figure 6-9 -
Wind Loading Analysis Wall Components and Cladding Building
any Height Excel Calculator Spreadsheet
Per ASCE 7-05 Code for Buildings of Any Height
Using Method 2: Analytical Procedure (Section 6.5) -
Wind Loading Analysis Roofing Components and Cladding Excel
Per ASCE 7-05 Code for Bldgs. of Any Height with Gable Roof q <= 45o or Monoslope Roof q <= 3o
Wind Loading Analysis Chimneys, Stacks, and Vertical Tanks
Per ASCE 7-05 Code for Cantilevered Structures Classified as Other Structures -
Wind Loading Analysis Open Structures without Roofs Excel
Per ASCE 7-05 Code
Using Method 2: Analytical Procedure (Section 6.5) for Other Structures of Any Height - Wind Loading Analysis For Low Rise Building Excel Spreadsheet Calculator
- Wind Load on Electrical Wire Support Pole Calculator Spreadsheet Premium Account Required
- Wind and Seismic Load on Gable Steel Frame Calculator
- Wind Map US and Regional Basic Wind Speed Data Chart USA and regional wind data.
- Wind Loads on Gable Frame to Australian Wind Code AS1170.2 Spreadsheet Calculator
- Ultimate Moment of Resistance of Beam Spreadsheet Calculator
- Z Purlins Design Spreadsheet Calculator
Architectural
- Architects Handbook, 464 pages Premium Membership Minimum Required
- Architecture Design Notebook Free Membership Required
