Plate Shear Webs with Beads Critical Shear Stress Equation and Calculator |
Circular Membrane Stress and Deflection Design Calculator and Equations |
Long Rectangular Membrane Stress and Deflection Design Calculator and Equations |
Short Rectangular Membrane Stress and Deflection Design Calculator and Equations |
Flat Rectangular Plate with All Edges Simply Supported Stress and Deflection with circular Load applied at center Equation and Calculator. |
Flat Rectangular Plate Uniformly Increasing Loading Along Length Stress and deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain Formulas for flat plates with straight boundaries and constant thickness |
Flat Rectangular Plate Uniformly Increasing Loading Along Width Stress and deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain Formulas for flat plates with straight boundaries and constant thickness |
Flat Rectangular Uniform over entire plate plus uniform over entire plate plus uniform tension P lb=linear in applied to all edges Stress and deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain Formulas for flat plates with straight boundaries and constant thickness |
![Flat Rectangular Plate; Three Edges Simply Supported, one Edge (b) Free Stress and Deflection With Uniformly increasing along the a side Equation and Calculator.](graphics/plate-s-s-roarks-24.png)
Uniformly Increasing Force Applied |
Flat Rectangular Plate; Three Edges Simply Supported, one Edge (b) Free Stress and Deflection With Uniformly increasing along the a side Equation and Calculator. |
Flat Rectangular Plate; Three Edges Simply Supported, one Edge Fixed Stress and Deflection With Uniformly increasing along the a side Equation and Calculator. Per. Roarks Formulas for Stress and Strain. |
Flat Rectangular Plate; Three Edges Simply Supported, one long Edge Fixed Stress and Deflection With Uniform Loading over entire plate Equation and Calculator |
Flat Rectangular Plate; two long edges simply supported, two short edges fixed Uniform loading over entire plate Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate; two long edges fixed, two short edges simply supported Uniform loading over entire plate Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate; one edge fixed, opposite edge free, remaining edges simply supported loading 1/3 of plate from fixed edge Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain Formulas |
Flat Rectangular Plate; one edge fixed, opposite edge free, remaining edges simply supported loading Uniformly decreasing from fixed edge to free edge Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain Formulas |
Flat Rectangular Plate; one edge fixed, opposite edge free, remaining edges simply supported loading Uniformly decreasing from fixed edge to zero at 2/3 b Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate; one edge fixed, opposite edge free, remaining edges simply supported loading distributed line load w lb/in along free edge Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate; all edges fixed. Uniform loading over small concentric circle of radius ro (note definition of r'o) Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate, Three Edges Fixed, One Edge (a) Simply Supported Loading Over Entire Plate Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate, Three Edges Fixed, One Edge (a) Simply Supported Uniform Loading over 2/3 of plate from fixed edge Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate, Three Edges Fixed, One Edge (a) Simply Supported Uniform Loading over 1/3 of plate from fixed edge Stress and Deflection Equation and Calculator.
Per. Roarks Formulas for Stress and Strain for flat plates |
Flat Rectangular Plate, Three Edges Fixed, One Edge (a) Simply Supported Loading Uniformly decreasing from fixed edge to simply supported edge Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain for flat plates |
Flat Rectangular Plate, Three Edges Fixed, One Edge (a) Simply Supported Loading Uniformly decreasing from fixed edge to zero at 2/3b Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate, Three Edges Fixed, One Edge (a) Simply Supported Loading Uniformly decreasing from fixed edge to zero at 1/3b Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate, Three Edges Fixed, One Edge (a) Free Supported Loading Uniformly Over Entire Plate Stress and Reaction Loading Equation and Calculator. Per. Roarks Formulas for Stress and Strain for flat plates |
Flat Rectangular Plate, Three Edges Fixed, One Edge (a) Free Loading Uniform over 2/3 of Plate from Fixed Edge Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate, Three Edges Fixed, One Edge (a) Free Loading Uniform over 1/3 of Plate from Fixed Edge Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate, Three Edges Fixed, One Edge (a) Free Loading Uniformly decreasing from fixed edge to zero at free edge Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate, Three Edges Fixed, One Edge (a) Free Loading Uniformly decreasing from fixed edge to zero at 2/3b Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate, Three Edges Fixed, One Edge (a) Free Loading Uniformly decreasing from fixed edge to zero at 1/3b Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate, Two Edges Fixed, Two Edges Free Loading Uniform over Entire Plate Equation and Calculator. Per. Roarks Formulas for Stress and Strain for flat plates with straight boundaries and constant thickness |
Flat Rectangular Plate, Two Edges Fixed, Two Edges Free Uniform Loading over Plate from z = 0 to z = (1/3) b Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate, Two Edges Fixed, Two Edges Free Load Uniformly Decreasing from z = 0 to z = b Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate, Two Edges Fixed, Two Edges Free Load Uniformly Decreasing from z = 0 to z = (2/3) b Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Flat Rectangular Plate, Two Edges Fixed, Two Edges Free Load Uniformly Decreasing from z = 0 to z = (1/3) b Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Continuous Plate Supported at Equal Intervals "a" on Circular Supports of Radius ro Uniform Loading of Entire Plate Stress Equation and Calculator. Per. Roarks Formulas for Stress and Strain for flat plates |
Continuous Plate Supported on an Elastic Foundation of Modulus k (lb/in2/in) Stress and Deflection Equation and Calculator. Uniform Loading over a snall circle of radius ro remote from the edges. Per. Roarks Formulas for Stress and Strain |
Continuous Plate Supported on an Elastic Foundation of Modulus k (lb/in2/in) Stress and Deflection Equation and Calculator. Uniform loading over a small circle of radius ro, adjacent to edge but remote from corner. Per. Roarks Formulas for Stress and Strain |
Continuous Plate Supported on an Elastic Foundation of Modulus k (lb/in2/in) Stress and Deflection Equation and Calculator. Uniform loading over a small circle of radius ro, adjacent to corner. Per. Roarks Formulas for Stress and Strain |
Parallelogram plate (skew slab) all edges simply supported with uniform loading over entire plate Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Parallelogram plate (skew slab) shorter edges simply supported, longer edges free with uniform loading over entire plate Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Parallelogram plate (skew slab) all edges fixed with uniform loading over entire plate Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Equilateral triangle; all edges simply supported with uniform loading over entire plate Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Equilateral triangle plate; all edges simply supported with uniform loading over small circle of radius ro at x = 0; z = 0 Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Right-Angle Isosceles Triangle; all edges simply supported with uniform loading over entire plate Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Regular polygonal plate; all edges simply supported with uniform loading over entire plate Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Regular polygonal plate; all edges fixed with uniform loading over entire plate Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Rectangular plate, uniform load, clamped (Empirical) equations and calculator Rectangular plate, uniform load, clamped (Empirical) equations and calculator Symbols used: a = minor length of rectangular plate, (m, in) b = major length of rectangular plate, (m, in) p = uniform pressure loading, (N, lbs) v = Poisson???s ratio |
Concentrated load at center of Plate, clamped edges (empirical) equation and calculator Rectangular plate, circular concentrated load at center, clamped edges (empirical) equation and calculator. |
Baseplate with Large Moment to AISC LRFD Spreadsheet Calculator |
Moments and Reactions for Rectangular Plates using the Finite Difference Method This book of monograph presents a series of tables containing computed data for use in the design of components of structures which can be idealized as rectangular plates or slabs. Typical examples are wall and footing panels of counterfort retaining walls. The tables provide the designer with a rapid and economical means of analyzing the structures at representative points. The data presented, as indicated in the accompanying figure on the frontispiece, were computed for fivl: sets of boundary conditions, nine ratios of lateral dimensions, and eleven loadings typical of those encountered in design. |
Design Thickness of Pipe Blanks Caps Formula and Calculator per. ASME B31.5 |
Restrained Plate, Uniformly Heated Stress Calculator and Equations |
Partially Restrained Square Plate in Frame, Uniformly Heated Stress Calculator and Equations |
Partially Restraint of a Uniformly Heated Rectangular Plate Stress Calculator and Equations |
Plate Shear Buckling Stress Calculator and Equations |
Structural Composite Sandwich Stiffness Equation and Calculator |
Structural Composite Sandwich Wrinkling Stress Equation and Calculator
Structural Composite Honeycomb Core Wrinkling Stress Equation and Calculator |
