ISO Metric Hardware Specifications Table Chart - Engineers Edge
ANSI Hardware Menu
Fastener and Screw / Bolt Design, Formula and Calculations
- The following are to links of ISO Metric Hardware Specifications Table Charts
- Should you find any errors omissions broken links, please let us know - Feedback
- Do you want to contribute to this section? See Premium Publisher Program
** Search this WEBPAGE, click on Magnifying Glass **
The hardware references contained in these links are provided for your convenience. The accuracy of these specifications are not guaranteed and, the user of these tables should verify all data contained herein.
Allen Hexagon Tools Metric Size Table, Hex Key, Hexagon Keys Metric Series Tools
- British Association BA Screws Threads tapping and clearance drills table
- Dowel Pins per. DIN EN ISO 8734
- Fastener Design Engineering Manual - Premium Membership Required
- Hexagon and Spline Sockets for Socket Head Cap Screws Data
- Slotted Hex Nuts per. B18.2.4.4M
- Fasteners Comprehensive Technicians Guide
- Flange Metric Nut Dimension Table per. ANSI B18.2.4.4M
- Jam Nuts, Metric per. ANSI B18.2.4.5M
- Torque Nuts, Metric per. ANSI B18.16.3M
- Hex Nuts Metric per. B18.2.4.1M and B18.2.4.2M
- BS EN ISO 898-6 Proof load values and Minimum Stripping Strength of nuts
- BS EN ISO 4032 Hexagon nuts style 1 – product grades A and B
- BS EN ISO 4033 Hexagon nuts style 2 – product grades A and B
- BS EN ISO 4034 Hexagon nuts style 1 – product grade C
- BS EN ISO 4035 Hexagon thin nuts chamfered – product grades A and B
- BS EN ISO 4036 Hexagon thin nuts (unchamfered) – product grade B
- Lag Screw Metric Size and Dimensions per. ANSI B18.2.3.8M
- BS ISO EN DIN 20898-7 Mechanical properties of fasteners: torsional test and minimum torques for bolts and screws with nominal diameters 1–10 mm
- BS EN ISO 10642 Hexagon socket countersunk head screws
- BS 4320 Plain Washer, Bright Metric Series
- BS 4320 Plain Washer, Black Metric Series
- BS 4464 Split Coil Washer Spring Metric Series Type A
- BS 4464, Single Coil Rectangular Spring Washer, Metric Series Types B and BP
- BS 4464 Double Coil Rectangular Section Spring Washer: Metric Series, Type D
- BS ISO EN 4463 Metric Crinkle Washers Specifications
- DIN 6797 Toothed lock washers, metric
- DIN 6798 Serrated Lock Washers, Metric
- Force Required to Strip the Bolt Threads Formula and Calculator
- Force Required to Strip the Bolt Threads Any Length Formula and Calculator
- ISO metric tapping and clearance drills, coarse thread series
- ISO metric tapping and clearance drills table chart, fine thread series
- ISO 68-1 Basic Metric Thread Profile Specifications and Equations
- Method and Equations of Analysis BS449: Part 2
- Lag Screws per. ANSI/ASME B18.2.1 Standard Inch Size Hex
- Loading Capacities of Ordinary Bolts per. BS449: Part 2 Bolt Grade 4.6
- Loading Capacities of Ordinary Bolts per. BS449: Part 2 Bolt Grade 6.8
- Loading Capacities of Ordinary Bolts per. BS449: Part 2 Bolt Grade 8.8
- Loading Capacities of Ordinary Bolts per. BS449: Part 2 Bolt Grade 10.9
- Length of Screw Thread Engagement per. ISO 965-1 Calculator, Formula and Table Length of engagement of mating threads is selected to utilize full tensile strength of a bolt prior to shearing and nut threads.
- Lowenherz or Löwenherz Thread Size Table
- Excel Spreadheet Design Calculator per. BS: 449: Part 2 requires an active Premium Membership with Engineers Edge
- Material Tensile Shear and Yield Strength of Engineering Materials Table
- Metric Helical Coil Threaded Insert Hole Data per. ASME B18.29.8M - 2005
- Helical Coil Threaded Insert Install Torque per. ASME B18.29.2M Metric
- Metric M Series Thread Stress and Shear Areas
- Metric External (Fasteners) Thread Designations Sizes M0.25 - M1.4
- Metric External (Fasteners) Thread and Fastener Sizes M20 - M55
- Metric External (Fasteners) Thread and Fastener Sizes M56 - M78
- Metric External (Fasteners) Thread and Fastener Sizes M80 - M100
- Metric External (Fasteners) Thread and Fastener Sizes M105 - M135
- Metric External (Fasteners) Thread and Fastener Sizes M140 - M175
- Metric External (Fasteners) Thread and Fastener Sizes M180 - M255
- Metric External (Fasteners) Thread and Fastener Sizes M260 - M1060
- Metric Internal (Fasteners) Thread Designations Sizes M0.25 - M8
- Metric Internal (Fasteners) Thread Designations Sizes M9 - M24
- Metric Internal (Fasteners) Thread Designations Sizes M24 - M50
- Metric Internal (Fasteners) Thread Designations Sizes M52 - M72
- Metric Internal (Fasteners) Thread Designations Sizes M75 - M120
- Metric Internal (Fasteners) Thread Designations Sizes M125 - M180
- Metric Internal (Fasteners) Thread Designations Sizes M185 - M230
- Metric Internal (Fasteners) Thread Designations Sizes M235 - M600
- Metric Helical Helicoil threaded insert per. ASME B18.29.2M manufacturing installation specifications
- Metric Plain Flat Washers Per. ANSI B18.22M
- Flat Washers per. DIN 125
- Metric Hex Nuts, Styles 1 and 2 ANSI/ASME B18.2.4.1M and B18.2.4.2M
- Metric Socket Head Screw per. ANSI/ASME B18.3.1M
- Bolt Multiple Diameters Change of Length Under Axial Force Formula and Calculator
- Whitworth British Standard Pipe (BSP) Thread DIN ISO 228
- Thread Designations and Symbols A-N
- Thread Designations and Symbols N-Z
- ANSI, ISO Thread Designations and References
- Metric Threads ISO 724
- BS 4620 Cold Forged Snap Head Rivet Sizes and Dimensions Table
- BS 4620 Hot Forged Snap Head Rivet Sizes and Dimensions Table
- Strength Grade Designation System of Steel Bolts and Screws
- Engineering Hardware Directory
- Minimum ultimate tensile loads and proofing loads BS EN ISO 898-1
- BS EN ISO 898-1 Proofing loads ISO metric coarse pitch thread
- ISO Stress Area Equation and Calculator - Proof load values are given in BS EN 20898-2:
- BS EN 20898-2 Proof load values - Coarse thread
- Tap Drill Hole Size based on Precentage of Full Thread Equation and Calculator
- Tap Drill or Core Hole Sizes for Cold Form Tapping ISO Metric Threads
- T-Slot Profile Design per. BS 2485
- T-Bolts and T-Nuts Dimensions per. BS 2485
- T-Nuts per. ASME B5.1M Table of dimensions and tolerances, Inch and (metric) mm units
- Guide to Design Criteria for Bolted and Riveted Joints
- Pitch Diameter of Threads Calculator and Formula
- Rod of Nonuniform Diameter, Change of Length Under Axial Force Formula and Calculator
- Single-Riveted Lap-Joint with Inside Cover Plate Formulas and Calculator for Stress and Strength Design
- Double-Riveted Lap-Joint with Inside Cover Plate Formulas and Calculator for Stress and Strength Design.
- Prevailing Torque Specification Guide for Metric ISO Hardware Sizes
Parallel Key and Taper Keys Dimensions and Sizes per. ISO 6885, Part 1, 6886 and 6887
Side fitting square and rectangular keys
Square and rectangular taper keys - Retaining Snap Ring Stress and Failure Formulas and Calculator
- Retaining Snap Ring Groove Stress and Failure Formulas and Calculator
- Torx Head Fastener Basic Dimensions per. ISO 10664
- Typical Elongation Chart for Common Bolting Materials
- Washers Controlling loosening of Full Threaded Bolted Joints
