Cylindrical Pressure Vessel Uniform Axial Load Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Cylindrical Pressure Vessel Uniform Radial Load Equation and Calculator. Per. Roarks Formulas for Stress and Strain for membrane stresses and deformations in thin-walled pressure vessels. |
Cylindrical Pressure Vessel Uniform Internal or External Pressure, Ends Capped Equation and Calculator. Per. Roarks Formulas for Stress and Strain for membrane stresses and deformations in thin-walled pressure vessels. |
Cylinder Linearly Varying Radial Pressure Stress and Deflection Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Cylinder Stress and Deflection by Own Weight Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Cylinder Stress and Deflection Uniform rotation, ω rad/sec about central axis Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Lames Equation Thick-walled Cylinders of Brittle Material, Ends Open or Closed Formula and Calculator |
Thick Walled Cylinder Stress Pressure Vessel Equations and Calculator
Thick-walled cylinders have application in all sorts of machine elements and will be the basis for the presentation for shrink or press fits. |
Axial Stress Thick Wall Cylinder Equations and Calculator If the pressure (pi) is confined at the ends, an axial (longitudinal) stress (σa) is also developed. It is assumed that the external pressure po is zero. |
Thick-walled Cylinders of Ductile Material, Closed Ends Clavarino's Formula and Calculator |
Thick-walled Cylinders of Ductile Material, Open Ends Birnie's Formula and Calculator |
Thin-Walled Cylinders of Cast Iron With Internal Pressure Formula and Calculator |
Truncated Cone Cylinder Stress and Deflection by Uniform loading on the horizontal projected area; tangential top edge support. Equation and Calculator.
Cone Cylinder Stress and Deflection by Uniform rotation, ω rad/s, about central axis Equation and Calculator. Per. Roarks Formulas for Stress and Strain |
Spherical Cylinder Stress and Deflection by Uniform internal or external pressure, q force/unit area; tangential edge support Equation and Calculator.
Thin Walled Sphere Stress Pressure Vessel Equations and Calculator:
Thin-walled vessels are typically either spherical or cylindrical. Other geometries are possible, but their complexity precludes their inclusion in this webpage. |
Spherical Cylinder Stress and Deflection Filled to depth d with liquid of density d force/unit volume; tangential edge support Equation and Calculator.
Spherical Cylinder Stress and Deflection Own weight, δ force/unit volume; tangential top edge support Equation and Calculator.
Spherical Cylinder Stress and Deflection Tangential loading only; resultant load = P Equation and Calculator.
Per. Roarks Formulas for Stress and Strain for membrane stresses |
Spherical Cylinder Stress and Deflection Uniform loading, w force/unit area; on the horizontal projected area; tangential top edge support Equation and Calculator.
Any smooth figure of revolution if R2 is less than infinity Uniform internal or external pressure, q force/unit area; tangential edge support Stress and Deflection Equation and Calculator.
Any smooth figure of revolution if R2 is less than infinity Stress and Deflection Equation and Calculator.
Filled to depth d with liquid of density δ force / unit volume; tangential edge support. W = weight of liquid contained to a depth y. |
Own weight, δ force/unit volume; tangential top edge support. W = weight of vessel below the level y. |
Any smooth figure of revolution if R2 is less than infinity Stress and Deflection Equation and Calculator. Tangential Loading Only, resultant load = P, Per. Roarks Formulas for Stress and Strain |
Any smooth figure of revolution if R2 is less than infinity Stress and Deflection Equation and Calculator. Uniform loading, w force/unit area, on the horizontal projected area; tangential top edge support Per. Roarks Formulas for Stress and Strain |
Toroidal Shell Stress and Deflection Equation and Calculator. Uniform Internal or External pressure, q force/unit area. Per. Roarks Formulas for Stress and Strain |
Flat Plate Circular Analysis and Design Excel Spreadsheet Calculator
Spreadsheet Calculator per. Roark's Stress and Strain Formulas, 5th Edition |
ASME BPVC Rules Summary and Overview |
Pipe Stress due to Clamping Force Spreadsheet Calculator
This spreadsheet calculates the a variety of resultant engineering requirments per. Roark's Formulas for Stress and Strain, 7th edition, Table 9.2 Case 1, Pressure Vessel Design Manual, 3rd Edition, ASME B31.1-2006 |
Pressure Vessel Temperature Ratings for Group 1.1 Materials per. ASME B16.5 Pipes Flanges and Flanged Fittings. |
Pressure Vessel Temperature Ratings for Group 1.2 Materials per. ASME B16.5 Pipes Flanges and Flanged Fittings. |
Pressure Vessel Temperature Ratings for Group 1.3 Materials per. ASME B16.5 Pipes Flanges and Flanged Fittings. |
Pressure Vessel Temperature Ratings for Group 1.4 Materials per. ASME B16.5 Pipes, Flanges and Flanged Fittings. |
Pressure Vessel Temperature Ratings for Group 1.5 Materials per. ASME B16.5 Pipes, Flanges and Flanged Fittings. |
Pressure Vessel Temperature Ratings for Group 1.7 Materials per. ASME B16.5 Pipes, Flanges and Flanged Fittings. |
Pressure Vessel Temperature Ratings for Group 1.9 Materials per. ASME B16.5 Pipes, Flanges and Flanged Fittings. |
Pressure Vessel Temperature Ratings for Group 1.10 Materials per. ASME B16.5 Pipes, Flanges and Flanged Fittings. |
Pressure Vessel Temperature Ratings for Group 1.11 Materials per. ASME B16.5 Pipes, Flanges and Flanged Fittings |
Pressure Vessel Temperature Ratings for Group 1.13 Materials per. ASME B16.5 Pipes, Flanges and Flanged Fittings |
Pressure Vessel Temperature Ratings for Group 1.14 Materials per. ASME B16.5 Pipes, Flanges and Flanged Fittings. |
Pressure Vessel Temperature Ratings for Group 1.15 Materials per. ASME B16.5 Pipes, Flanges and Flanged Fittings. |
Pressure Vessel Temperature Ratings for Group 1.17 Materials per. ASME B16.5 Pipes, Flanges and Flanged Fittings |
![Pressure Vessel](imagefiles/13906.jpg) |
ASME Pressure Vessel Code Maximum Allowable Stress Values |
Pressure Vessel Maximum Allowed Out of Circular Form (Roundness) forUnder External Pressure |
ASME Pressure Vessel – Piping, Drums, and Headers Pressure and Wall Thickness Equations and Calculator |
ASME Pressure Vessel Boiler Tubes Thickness Pressure Equation and Calculator |
Thin Cylindrical Shells: Equations and Calculator ASME Pressure Vessel Code |
Thick Cylindrical Shells Equations and Calculator ASME SECTION VIII |
External Pressure Vessel Calculations and Design |
Gas Discharge Rate Atmosphere From a Pressure Vessel |
Geometric Chart Pressure Vessel Components External - Compressive Loadings |
Design Rules for Vacuum Chambers Premium Membership Required |
Pressure Vessel Design Calculations Handbook This pressure vessel design reference book is prepared for the purpose of making formulas, technical data, design and construction methods readily available for the designer, detailer, layoutmen and others dealing with pressure vessels. Premium Membership Required |
Stress in Cylindrical Shell Equation and Calculator |
Pressure Vessel Required Shell Thickness Chart #1 |
Pressure Vessel Required Shell Thickness Chart #2 |
Thickness of Circumferential Shells Under Internal Pressure |
ASME Pressure Vessel Section I: Dished Heads Equations and Calculator |
Thickness of Ellipsoidal Head Under Internal Pressure |
Stress in Pressure Vessel Flanged or Dished Head Section Seam Equation and Calculator |
Stress in Cylindrical Shell Long Seam Calculator |
![Pressure Vessel Cone Geometry Design Calculator](calculators/Cone_Design_Tool/cone_section.gif) |
Pressure Vessel Cone Stress & Pressure Design Calculator |
Stress in Sphere and Hemispherical Head Seam Equation and Calculator |
Circular Flat Head with Internal or External Pressure Equation and Calculator |
Circular Flat Head Welded with Internal or External Pressure Equation and Calculator |
Pressure Vessel Elliptical Head Design |
Stress in Ellipsoidal Head Seam Equation and Calculator |
Full-Hemispherical Head Calculator ASME Pressure Vessel Section I |
Pressure Vessel Flanged Dish Head Design Tool Calculator |
Pressure Vessel Torispherical Head Wall and Pressure Calculator |
Thickness of Longitudinal Stressed Shells Under Internal Pressure |
Stress in Cone or Conical Section Seam Equation and Calculator |
Buckling of Partial Cylinder Plate Calculation |
![Pressure Vessel Pipe](/imagefiles/pressure-vessel/pipe-longitudinal.png) |
Pressure Vessel Pipe Circumferential Stress (Longitudinal Joints) |
Pressure Vessel Pipe Longitudinal Stress (Circumferential Joints) |
Pressure Vessel Skirt Support for Vertical Column Design Spreadsheet Calculator |
Lifting Lug Design Spreadsheet Calculator |
Weld Weight and Area Spreadsheet Calculator Calculations for Double V, Single V, Compound V, Backing Strip and J groove weld weight and area. |
Collar Bolt Flange Pressure Vessel Spreadsheet Calculator |
Pressure Vessel , Thin Wall Longitudinal Stress Equations
Pressure Vessel , Thin Wall Longitudinal Stress Calculator |
Propane Tank (Pressure Vessel) Dimensional and Volume Data Calculator |
Pressure Vessel , Thin Wall Hoop Stress Equations
Pressure Vessel , Thin Wall Hoop Stress Calculator |
Pressure Vessel Nozzle Design Tool Calculator |
Pressure Vessel Nozzle Design Spreadsheet Calculator, Design calculations for pressure vessel nozzle per. UG-37, Appendix 1-10, 1-7 and div 2. |
Pressure Vessel Nozzle with Repad Design Tool per. ASME VIII-1 |
Acceptable types of welded nozzle designs and other connections to pressure vessel shells, heads and other geometries. |
Pressure Vessel External Pressure Calculations |
Pressure Vessel Partition Plate Design Spreadsheet Calculator |
Standard Size Steel Pipe Weights Calculator |
Pressure Piping Minimum Wall Thickness Equations and Calculator ASME I and ASME-ANSI B31 |
Reinforcement Pressure Vessel Wall Thickness Plate Equations and Calculator ASME Pressure Vessel Section VIII |
Xtra Strong (XS) Size Steel Pipe Weights Calculator |
Double Xtra Strong (XXS) Size Steel Pipe Weights Calculator |
Pressure Vessel and Piping Weld Joint Reduction Factor - Weld Joint Corrosion Reduction Factor |
Hydrostatic Pressure Tests Pressure Vessels - ASME Pressure Vessels |
Welding Splice Design of Beam Spreadsheet Calculator |
Floating Head Exchanger Design Spreadsheet Calculator Pressure Vessel AES Type |
Storage Tank Design Spreadsheet Calculator per. API 650 |
Tube Sheet Design Spreadsheet Calculator per. API 650 |
Pressure vessel Flange Check Design Spreadsheet Calculator per. ASME Section VIII Div. 1 & TEMA 9th Edition |
Cylindrical Shell Internal and External Pressure Vessel Spreadsheet Calculator |
Vertical Storage Tank Selection Excel Spreadsheet Calculator |
Welded Joint Efficiency Table Recommendations |
Storage Tank Baffle Design Excel Spreadsheet Calculator |
High Density Polyethylene (HDPE) Liners For Steel Pipe Excel Spreadsheet Calculator |
Thermal Relief Load and Pressure Rise Macro Excel Spreadsheet Calculator |
Draining Time for Vertical Tank Formulas and Calculator |
Draining Time for Spherical (Sphere) Tank Formulas and Calculator |
Pressurized Gas Blowout Time Pipeline Excel Spreadsheet Calculator
Mass Flow Rate for Gas Pipeline Blowdown through Hole or Orifice Excel Spreadsheet Calculator |
Carbon Steel and High Yield Strength Pipe FIG. 17-27 (GPSA BOOK), Gas Transmission and Distribution Piping, Code for Pressure Piping ANSI B31.8-1982 (Values apply to A106, API 5LX pipe having the same specified minimum yield strength as shown) |
Misc. Pressure Vessel Applications
