Section Area Moment of Inertia Properties Area Moment of Inertia of Common Shapes
Engineering Metals and Materials Table of Contents
Engineering Analysis Menu
The following links are to calculators which will calculate the Section Area Moment of Inertia Properties of common shapes. The links will open a new browser window. Each calculator is associated with web pageor on-page equations for calculating the sectional properties.
** Search this PAGE ONLY, click on Maginifying Glass **
All calculators require a java enabled browser.
Structural Shapes Properties Viewer
Structural Shapes Properties Viewer W, S, M, HP C, MC, WT, ST Single Angles, Double Angles, Rectangular HSS shapes, Plates, Round HSS and Pipes. 500 + structural Profile configurations
Section Area Moment of Inertia Properties Square At Center
Section Properties Engineering
Section Properties Case 1 Calculator
Section Modulus, Radii of Gyration Equation and Rectangular Sections Equations
Section Area Moment of Inertia Properties Square Rotated 90 Deg At Center
Section Properties Case 3 Calculator
Section Area Moment of Inertia Properties Square At Edge
Section Properties Case 2 Calculator
Section Modulus, Radii of Gyration Equationand Rectangular Sections Equation
Section Area Moment of Inertia Properties Square Tube At Center
Section Properties Case 4 Calculator
Section Area Moment of Inertia Properties Square Tube Rotated 90 Deg At Center
Section Properties Case 5 Calculator
Channel Section
Section Properties Channel Case 28 Calculator
Section Modulus, Radii of Gyration Circular, Channel Shape Equations
Channel Section
Section Properties Channel Case 29 Calculator
Channel Section
Section Properties Channel Case 30 Calculator
Channel Section
Section Properties Channel Case 31 Calculator
Section Area Moment of Inertia Properties Round at Center
Moment of Inertia, Section Modulus, Radii of Gyration
Section Properties Case 17 Calculator
Section Modulus, Radii of Gyration Circular, Eccentric Shape Equations
Section Properties Case 18 Calculator
Section Properties Case 19 Calculator
Section Properties Case 20 Calculator
Section Properties Case 21 Calculator
Section Properties Case 22 Calculator
Section Area Moment of Inertia Properties Half Round
Section Area Moment of Inertia Properties Hexagon At Center
Section Area Moment of Inertia Properties Trapezoid
Section Area Moment of Inertia Properties Triangle
Section Area Moment of Inertia Properties Partial Triangle
Oblique Triangle
Section Area Moment of Inertia Properties Oblique Triangle
Section Modulus Diamond Shape Center Neutral Axis Calculator
Section Area Moment of Inertia Properties Rectangle At Center
Section Properties Case 6 Calculator
Section Properties Case 7 Calculator
Section Area Moment of Inertia Properties Rectangle At Edge
Section Area Moment of Inertia Properties Rectangle At Angle
Open
Section Properties Case 8 Calculator
Section Properties Case 9 Calculator
Section Area Moment of Inertia Properties Rectangle Tube At??Center
Section Properties Case 10 Calculator
Section Properties of Parallelogram Equation and Calculator
Section Properties of Parallelogram Calculator
Section Properties of Parallelogram Equation and Calculator:
L Section
Section Properties Case 35 Calculator
Moment of Inertia, Section Modulus, Radii of Gyration Equations Angle Sections
L Section
Section Properties Case 36 Calculator
L Section
Section Properties Case 37 Calculator
Section Area Moment of Inertia Properties Round Tube At Center
Section Area Moment of Inertia Properties Half Round Tube
Parabolic Spandrel Section
Parabolic Spandrel Section Properties Equation and Calculator
Section Area Moment of Inertia Properties Hexagon Thru Corners
Octogon
Section Area Moment of Inertia Properties Hexagon Thru Sides
Section Area Moment of Inertia Properties Octagon Thru Sides
Section Properties Case 14 Calculator
Section Properties Case 15 Calculator
Section Properties Case 16 Calculator
Section Area Moment of Inertia Properties Triangle At Edge
Section Properties Case 11 Calculator
Triangular
Section Properties Case 12 Calculator
Steel W & S Flange Beam and Column Analysis / Code Check Calculator
I Beam
Universal I-Beam Section Modulus Bottom Neutral Axis Calculator
Universal Channel Section Modulus Bottom Neutral Axis Calculator
Section Modulus Various Shapes - Plastic Section Modulus (PNA
Section Properties Case 23 Calculator
Section Modulus, Radii of Gyration Equations W and S Profiles
Section Properties Case 24 Calculator
Section Properties Case 25 Calculator
Section Properties Case 26 Calculator
Section Properties Case 27 Calculator
Tee Section
Section Properties Tee Profile Case 32 Calculator
Moment of Inertia, Section Modulus, Radii of Gyration Equations T Sections
Tee Section
Section Properties Tee Profile Case 33 Calculator
Tee Section
Section Properties Tee Profile Case 34 Calculator
General Equation and Calculator Mass Moment of Inertia
Hollow Cylinder Mass Moment of Inertia
Rectangular Plane Mass Moment of Inertia Calculator
Rectangular Plate Mass Moment of Inertia Calculator on Edge
Solid Shaft Cylinder Equation and Calculator Mass Moment of Inertia
Solid Sphere Cylinder Equation and Calculator Mass Moment of Inertia
Thin Sphere Cylinder Equation and Calculator
Thin Wall Shaft Mass Moment of Inertia
www.engineersedge.com
Advertising | Contact
