Engineering Materials
Strength / Mechanics of Material Basics, General Equations and Definitions
** Search this PAGE ONLY, click on Magnifying Glass **
- 2D Static's Load Modeler and Calculator Create 2D static's model and solve for reaction forces.
- Allowable Stress Design Equations and Calculator
- Polar Area Moment of Inertia Equations and Calculators
- Polar Mass Moment of Inertia Equations and Calculator
- Brittle Fracture Analysis Calculator and Equation
- Creep
- Cylindrical Polar Moment of Inertia
- Shaft and Maximum Torque Moment
- Shaft in Torsion Reliability and Design Formula and Calculator
- Diameter of Solid Shaft Subjected to Simple Torsion Equation and Calculator
- Diameter of Solid Shaft Subjected to Simple Bending Equation and Calculator
- Diameter of Solid Shaft subjected to Combined Torsion and Bending Equation and Calculator
- Double Integration Method Example 4 Proof Simply Supported Beam of Length L with Partial Distributed Load
- Double Integration Method Example 3 Proof Cantilevered Beam
- Double Integration Method for Beam Deflections
- Engineering and Applications Factor of Safety Review
- Fatigue SN Curve Python Script Application
- Fracture Mechanics for Structural Adhesive Bonds Fracture mechanics methodology was developed and experimentally demonstrated for the prediction of the growth of bondline flaws in an adhesively bonded structure.
- Free Body Diagram
- Hardness
- Heat Treatment
- Impact and Sudden Loading Approximate Formulas Equations
- Impact Force of a Blow Formulae and Calculator: Impact force of a blow: A body that weighs W pounds and falls S feet from an initial position of rest is capable of doing WS foot-pounds of work.
- Marin Factors for Corrected Endurance Limit Fatigue The endurance limit (S'e) determined using Eq. 2 that is established from fatigue tests on a standard test specimen must be modified for factors that will usually be different for an actual machine element.
- Mass Impact Loading Equations
- Mass Moment of Inertia
- Material Strength
- Theoretical Mechanics, Kinematics, Dynamics and Static's Premium Membership Required to view Document/Book
- Modulus of Resilience Equation and Calculator
- Mohr's Circle for Plane Stress
- Mohr's Circle Simplified Video
- Mohr's Circle when normal stress in the X direction is negative
- Poisson's Ratio Definition & Equation
- Poisson's Ratio Metals Materials Chart
- Thick Wall Cylinder Press or Shrink Fits Interference and Pressure Equations and Calculator If two thick-walled cylinders are assembled by either a hot/cold shrinking or a mechanical press-fit, a pressure is developed at the interface between the two cylinders.
- Pressure Vessel External Pressure Calculations
- Shear Stress
- Shear Stress in Shafts Equations
- Shear Center for Beams Equations and Calculator
- Strain
- Stress Analysis Manual
- Stress Fundamentals
- Stress Concentration Fundamentals
- Thin Walled Pressure Vessel, Hoop Stress
- Torsional Deflection of Shaft
- Torsional Stability of Aluminum Alloy Seamless Tubing
- Torsion in Thin-Walled Noncircular Shells Formulas and Calculator
- Cylinder Stress and Deflection with Applied Torsion
- Von Mises Criterion ( Maximum Distortion Energy Criterion )
- Maximum Shear Stress Theory Fatigue of a Shaft or Axle Formula and Calculator
- Static Loading Shaft or Axle Analysis Formula and Calculator - Most shafts are subject to combined bending and torsion, either of which may be steady or variable. Maximum Shear Stress and Von Mises Stress
- Work ( Strain ) Hardening
- Moment of Inertia, Section Modulus, Radii of Gyration Equations Square and Rectangular Sections
- Moment of Inertia, Section Modulus, Radii of Gyration Equations Triangular, Hex Sections
- Moment of Inertia, Section Modulus, Radii of Gyration Equations Circular, Eccentric Shapes
- Moment of Inertia, Section Modulus, Radii of Gyration Equations I Sections
- Moment of Inertia, Section Modulus, Radii of Gyration Equations Channel Sections
- Moment of Inertia, Section Modulus, Radii of Gyration Equations T Sections
- Moment of Inertia, Section Modulus, Radii of Gyration Equations Angle Sections
- Rotating Solid Cylinder Stress Equations and Calculator Solid Cylinder Rotating at ω rad/s
- Hollow Cylinder Rotating Stress Equations and Calculator
- Tuning fork (cylindrical prongs) Equation and Calculator
- Vector Mechanics for Engineers, Statics and Dynamics Premium membership required. Mechanics can be defined as that science which describes and predicts the conditions of rest or motion of bodies under the action of forces.
- Young's Modulus of Common Engineering Materials
Fastener, Bolt Torque Installation Design
Fatigue
Material Specifications and Characteristics - Ferrous and Non-Ferrous
Vibration
Pinned Columns and Buckling
Fatigue
Machine Design
Misc Analysis
