Short Fiber Plastic Base Composites Engineering Design Handbook
Engineering and Design Materials
Ms. Joan B. Titus
Plastics Technical Evaluation Center (PLASTEC)
486 Pages
Open: Short Fiber Plastic Base Composites Engineering Design Handbook
Preface
This handbook deals with a specific class of fiber reinforced plastics/composites. The fibrous composites, in general, constitute one of the major groups of nonmetallic structural materials. Their performance has been demonstrated effectively in a variety of military applications. Increased usage is anticipated as new weapon systems and other items of military equipment are introduced or redesigned. The composites cover a broad range of physical properties. They include the continuous fiber reinforced materials that have exceptionally high strengths and moduli of elasticity. The short discontinuous fiber reinforced composites, which comprise the subject matter of this handbook, are at a lower strength level. It is believed that this material group -which is easier to process and less costly -offers numerous opportunities for design simplification, innovations in design, and improvements in maintenance and producibility. It is the purpose of the handbook to acquaint Army personnel with the characteristics of these materials. Emphasis is placed on the close relationship between material properties and the associated processes for fabricating these materials.
TOC
CHAPTER 1. INTRODUCTION
Short Fiber Compounds Defined
Significance of Fabrication and Molding
Processes
General
Molding Short Fiber Compounds
Classification of Polymer Based Composites
Particulates.
Continuous Fiber Reinforced
Discontinuous Fiber Reinforced
Fiber Reinforced Thermoplastics
Short Fiber Thermosets
Status of Short Fiber Thermosets
CHAPTER 2. THERMOSET MOLDING
COMPOUNDS
Sheet Molding Compounds (SMC)
Fabrication of SMC
Chemically Thickened Resins
Polyester Resins
Composition and Classification
Curing Mechanisms
Fiber Glass Reinforcement
Fillers and Additives
SMC Formulations
Bulk Molding Compounds (BMC)
Fabric ;tion of BMC
BMC Formulations
Preform Molding
Directed Fiber Preforming
Plenum Chamber Preforming
Mat Preforming
Preform Molding Formulations
Chopped Roving Compounds
Miscellaneous Material Processes
References
CHAPTER.3. MATERIAL PROPERTIES
Introduction
Conditioning Prior to Test.
Test Temperature
Testing for Flammability
Properties of Short Fiber Compounds Based on
Polyester Resins
Properties of SMC
Military Specification for SMC
Properties of BMC
Properties of Preform-Wet Lay-up Materials
Properties of Woven Fabrics With Polyester
Classification System for Short Fiber Polyester
Base Compounds
Epoxy Resin Systems
CHAPTER4. STRENGTH AND STIFFNESS OF
SHORT FIBER COMPOSITES
Quasi-Isotropic Laminate Analogy
Reinforcement Efficiency
CHAPTER 5. MOLDING SHORT FIBER
THERMOSETS
Introduction
Presses for Compression Molding
Hydraulic Presses
Types
Performance Criteria, Hydraulic Presses
Mechanical Presses
Transfer Molding Presses
Injection Molding Machines
Matched Die Molding
Press Requirements
Features in Mold Design
Material Factors in Design
Molding Parameters.
Summary of Molding Methods
Military and Federal Specifications
