Related Resources: Heat Transfer
Heat Exchanger Optimization
Heat Transfer Engineering
Heat Exchanger Design and Engineering
Copnrad P. Hedderich
Naval Post Graduate School
382 Pages
Open: Heat Exchanger Optimization
Preface
A computer code was developed for the analysis of aircooled heat exchangers and was coupled with a constrained function minimization code to produce an automated air-cooled heat exchanger design and optimization program with many new capabilities.
A general iteration free approximation method was used for the analysis which calculates the mean overall heat transfer coefficient and the overall pressure drop for many flow arrangements, taking into account the variation of the heat transfer coefficients and the pressure drop with temperature and/or length of flow path.
The code is not limited to surfaces found in the literature, but will accommodate any triangular pitch bank of finned tubes in multiple-pass configurations.
TOC
I. INTRODUCTION 12
A. BACKGROUND 12
B. REVIEW 13
C. METHODOLOGY 17
D. OBJECTIVES 18
II. NUMERICAL OPTIMIZATION 19
A. BACKGROUND 19
B. CONSTRAINED FUNCTION MINIMIZATION (CONMIN) 20
C. CONTROL PROGRAM FOR ENGINEERING SYNTHESIS (COPES) 27
III. HEAT EXCHANGER ANALYSIS 30
A. INTRODUCTION 30
B. PROBLEM FORMULATION 30
C. PERFORMANCE CALCULATION PROCEDURE 33
1. Log Mean Temperature Difference 33
2. Determination of Reference Temperatures
3. Correction of Reference Temperatures for Given Arrangement
4. Uncorrected Tubeside Heat Transfer Coefficient 40
5. Calculation of Wall and Associated Resistances ^2
6. Calculation of Airside Heat Transfer Coefficients
7. Calculation of Fin and Surface Efficiencies
8. Correction of the Tubeside Heat Transfer Coefficient
9. Calculation of Air and Tubeside Pressure Drops 46
10. Objective and Constraint Functions 48
IV. RESULTS 52
A. BACKGROUND 52
B. CASE STUDIES 54
1. Case One 54
2. Case Two 60
V. CONCLUSIONS 65
VI. RECOMMENDATIONS 68
VII. FIGURES 70
Appendix A: USER'S MANUAL 89
Appendix B: SAMPLE USER'S INPUT 115
Appendix C: SAMPLE OUTPUT FROM COPES 126
Appendix D: ANALIZE PROGRAM LISTING 139
LIST OF REFERENCES 184
INITIAL DISTRIBUTION LIST 188
List of Figures:
Figure
1. Flowchart for ANALIZ 70
2. Numerical Optimization Techniques 71
3. Usable-Feasible Direction 72
4. One Dimensional Search 73
5. Two-Variable Design Space with Initial Design 74
6. Two-Variable Design Space with First Iteration — 7 5
7. Two-Variable Design Space with Second Iteration - 76
8. Two-Variable Design Space with Third Iteration — 77
9. Two-Variable Design Space with Fourth Iteration - 78
10. General Configuration of Air-Cooled Heat Exchanger 79
11. Thermal Conductivity of Dry Air at Atmospheric Pressure 80
12. Thermal Conductivity of Saturated Water 81
13. Viscosity of Dry Air at Atmospheric Pressure 8 2
14. Viscosity of Saturated Water 83
15. 4 Row, 2 Pass Arrangement 84
16. DRATIO Constraint 85
17. THETA Constraint 8 5
18. Design Optimum - Case Study One 8 6
19. Design Optimum - Case Study Two 87
20. Two-Variable Function Space 88
