Related Resources: Heat Transfer
Principles of Refrigeration
Open:
  • Pressure, work, power, and energy
  • Matter, internal energy, heat, temperature
  • Thermodynamic processes
  • Saturated and superheated vapors
  • Psychrometric properties of air
  • Refrigeration and the vapor compression system
  • Cycle diagrams and the simple saturated cycle
  • Actual refrigerating cycles
  • Survey of refrigeration applications
  • Cooling load calculations
  • Evaporators
  • Performance of reciprocating compressors
  • System equilibrium and cycling controls
  • Condensers and cooling towers
  • Fluid flow, centrifugal liquid pumps water and brine piping
  • Refrigerant
  • Refrigerant flow controls
  • Compressor construction and lubrication
  • Refrigerant piping and accessories
  • Defrost methods, low-temperature systems, and multiple temperature installations
  • Electric motors and control circuits
