Calculator Rectangular Cantilever Beam in Direct Compression and Bending Equationsr
Rectangular Cantilever Beam in Direct Compression and Bending:
Rule 1: For every calculated normal stress there is a corresponding induced shear stress; the value of the shear stress is equal to half that of the normal stress.
Rule 2: For every calculated shear stress there is a corresponding induced normal stress; the value of the normal stress is equal to that of the shear stress. The tables of combined stress formulas, below, include equations for calculating both maximum nominal tensile or compressive stresses, and maximum nominal shear stresses.
Maximum Nominal
Shear Stress
L = | Length of Beam | inches | (mm) |
h = | Height of Beam | inches | (mm) |
b = | Width of Beam | inches | (mm) |
Fy = |
Applied Load | lbs | (N) |
Fx = | Applied Load | lbs | (N) |
σ' a = |
Stress, Tensile or Compressive | Lbs/in2 | (N/mm2) |
σ' b = | Stress, Tensile or Compressive | Lbs/in2 | (N/mm2) |
τ'a = | Stress , Max. Nominal Shear | Lbs/in2 | (N/mm2) |
τ'b = | Stress , Max. Nominal Shear | Lbs/in2 | (N/mm2) |
- Machinery's Handbook, 21st Edition, Page 404 or,
- Machinery's Handbook, 23st Edition, Page 260 or,
- Machinery's Handbook, 27st Edition, Page 261
