MONORAIL BEAM ANALYSIS |
For S-shaped Underhung Monorails Analyzed as Simple-Spans with / without Overhang |
Per AISC 9th Edition ASD Manual and CMAA Specification No. 74 (2004) |
Input: |
Monorail Size: |
Select: |
Design Parameters: |
Beam Fy = |
ksi |
Beam Simple-Span, L = |
ft. |
Unbraced Length, Lb = |
ft. |
Bending Coef., Cb = |
Overhang Length, Lo = |
ft. |
Unbraced Length, Lbo = |
ft. |
Bending Coef., Cbo = |
Lifted Load, P = |
kips |
A = |
in.^2 |
d/Af = |
Trolley Weight, Wt = |
kips |
d = |
in. |
Ix = |
in.^4 |
Hoist Weight, Wh = |
kips |
tw = |
in. |
Sx = |
in.^3 |
Vert. Impact Factor, Vi = |
bf = |
in. |
Iy = |
in.^4 |
Horz. Load Factor, HLF = |
tf = |
in. |
Sy = |
in.^3 |
Total No. Wheels, Nw = |
k= |
in. |
J = |
in.^4 |
Wheel Spacing, S = |
ft. |
rt = |
in. |
Cw = |
in.^6 |
Distance on Flange, a = |
in. |
Support Reactions: |
Results: |
RR(max) = |
RL(min) = |
Parameters and Coefficients: |
Pv = |
kips |
Pw = |
kips/wheel |
Ph = |
kips |
ta = |
in. |
l = |
l = 2*a/(bf-tw) |
Cxo = |
Cxo = -1.096+1.095*l+0.192*e^(-6.0*l) |
Cx1 = |
Cx1 = 3.965-4.835*l-3.965*e^(-2.675*l) |
Czo = |
Czo = -0.981-1.479*l+1.120*e^(1.322*l) |
Cz1 = |
Cz1 = 1.810-1.150*l+1.060*e^(-7.70*l) |
Bending Moments for Simple-Span: |
x = |
ft. |
Mx = |
ft-kips |
My = |
ft-kips |
Lateral Flange Bending Moment from Torsion for Simple-Span: |
(per USS Steel Design Manual, 1981) |
e = |
in. |
at = |
Mt = |
ft-kips |
X-axis Stresses for Simple-Span: |
fbx = |
ksi |
Lb/rt = |
Fbx = |
ksi |
SR = |
Y-axis Stresses for Simple-Span: |
fby = |
ksi |
fwns = |
ksi |
fby(total) = |
ksi |
Fby = |
ksi |
SR = |
Combined Stress Ratio for Simple-Span: |
S.R. = |
SR = |
Vertical Deflection for Simple-Span: |
Pv = |
kips |
D(max) = |
in. |
D(max) = |
D(ratio) = |
D(ratio) = L*12/D(max) |
D(allow) = |
in. |
D(allow) = L*12/450 |
SR = |
Bending Moments for Overhang: |
Mx = |
ft-kips |
My = |
ft-kips |
Lateral Flange Bending Moment from Torsion for Overhang: |
e = |
in. |
at = |
Mt = |
ft-kips |
X-axis Stresses for Overhang: |
fbx = |
ksi |
Lbo/rt = |
Fbx = |
ksi |
SR = |
Y-axis Stresses for Overhang: |
fby = |
ksi |
fwns = |
ksi |
fby(total) = |
ksi |
Fby = |
ksi |
SR = |
Combined Stress Ratio for Overhang: |
S.R. = |
SR = |
Vertical Deflection for Overhang: |
Pv = |
kips |
D(max) = |
in. |
D(max) = |
D(ratio) = |
D(ratio) = Lo*12/D(max) |
D(allow) = |
in. |
D(allow) = Lo*12/450 |
SR = |
Bottom Flange Bending (simplified): |
be = |
in. |
tf2 = |
in. |
am = |
in. |
Mf = |
in.-kips |
Sf = |
in.^3 |
fb = |
ksi |
Fb = |
ksi |
SR = |
Bottom Flange Bending per CMAA Specification No. 74 (2004): |
(Note: torsion is neglected) |
Local Flange Bending Stress @ Point 0: |
(Sign convention: + = tension, - = compression) |
sxo = |
ksi |
sxo = Cxo*Pw/ta^2 |
szo = |
ksi |
szo = Czo*Pw/ta^2 |
Local Flange Bending Stress @ Point 1: |
sx1 = |
ksi |
sx1 = Cx1*Pw/ta^2 |
sz1 = |
ksi |
sz1 = Cz1*Pw/ta^2 |
Local Flange Bending Stress @ Point 2: |
sx2 = |
ksi |
sx2 = -sxo |
sz2 = |
ksi |
sz2 = -szo |
Resultant Biaxial Stress @ Point 0: |
sz = |
ksi |
sz = fbx+fby+0.75*szo |
sx = |
ksi |
sx = 0.75*sxo |
txz = |
ksi |
txz = 0?? (assumed negligible) |
sto = |
ksi |
sto = SQRT(sx^2+sz^2-sx*sz+3*txz^2) |
SR = |
Resultant Biaxial Stress @ Point 1: |
sz = |
ksi |
sz = fbx+fby+0.75*sz1 |
sx = |
ksi |
sx = 0.75*sx1 |
txz = |
ksi |
st1 = |
ksi |
st1 = SQRT(sx^2+sz^2-sx*sz+3*txz^2) |
SR = |
Resultant Biaxial Stress @ Point 2: |
sz = |
ksi |
sz = fbx+fby+0.75*sz2 |
sx = |
ksi |
sx = 0.75*sx2 |
txz = |
ksi |
st2 = |
ksi |
st2 = SQRT(sx^2+sz^2-sx*sz+3*txz^2) |
SR = |
S-Beam Configurations |
