Related Resources: belt design
Synchronous Timing Belt Lengths and Tolerances per. ANSI RMA IP-24, ISO 5299 and IS 9804
Synchronous Timing Belt Standard Pitch Lengths and Tolerances per. ANSI RMA IP-24, ISO 5299 and IS 9804.
- Synchronous Timing Belt Tooth Section Dimensions Table per ANSI / RMA IP-24
- Synchronous Timing Belt Pulley Dimensions Table per ANSI / RMA IP-24
The pitch length of a synchronous belt is determined by placing the belt on a measuring fixture having two pulleys of equal diameter, a method of applying force, and a means of measuring the center distance between the two pulleys. The position of one of the two pulleys is fixed and the other is movable along a graduated scale.
All dimensions are given in inch units
Synchronous Belt Standard Pitch Lengths and Tolerances ANSI/RMA IP-24
Belt Length
Designation |
Pitch
Length |
Permissible Deviation
From Standard Length |
Number of Teeth for
Standard Lengths |
MXL
(0.080) |
XL
(0.200) |
L
(0.375) |
H
(0.500) |
XH
(0.875) |
XXH
(1.250) |
36
40 44 48 56 |
3.600
4.000 4.400 4.800 5.600 |
±0.016
±0.016 ±0.016 ±0.016 ±0.016 |
45
50 55 60 70 |
60
64 70 72 80 |
6.000
6.400 7.000 7.200 8.000 |
±0.016
75
80 … 90 100 |
30
… 35 … 40 |
88
90 100 110 112 |
8.800
9.000 10.000 11.000 11.200 |
±0.016
±0.016 ±0.016 ±0.018 ±0.018 |
110
… 125 … 140 |
45 50 55 … |
120
124 124 130 140 |
12.000
12.375 12.400 13.000 14.000 |
±0.018
±0.018 ±0.018 ±0.018 ±0.018 |
… 155 … 175 |
60
... ... 65 70 |
33 ... ... ... |
150
160 170 180 187 |
15.000
16.000 17.000 18.000 18.750 |
±0.018
±0.020 ±0.020 ±0.020 ±0.020 |
200 … 225 … |
75
80 85 90 ... |
40
... ... ... 50 |
190
200 210 220 225 |
19.000
20.000 21.000 22.000 22.500 |
±0.020
±0.020 ±0.024 ±0.024 ±0.024 |
250 … … … |
95
100 105 110 ... |
... 56 ... 60 |
Belt Length
Designation |
Pitch
Length |
Number of Teeth for
Standard Lengths |
MXL
(0.080) |
XL
(0.200) |
L
(0.375) |
H
(0.500) |
XH
(0.875) |
XXH
(1.250) |
230
240 250 255 260 |
23.000
24.000 25.000 25.500 26.000 |
±0.024
±0.024 ±0.024 ±0.024 ±0.024 |
112
120 125 ... 130 |
64 ... 68 ... |
48 … … … |
270
285 300 322 330 |
27.000
28.500 30.000 32.250 33.000 |
±0.024
±0.024 ±0.024 ±0.026 ±0.026 |
72
76 80 86 ... |
54
... 60 ... 66 |
345
360 367 390 420 |
34.500
36.000 36.750 39.000 42.000 |
±0.026
±0.026 ±0.026 ±0.026 ±0.030 |
92
... 98 104 112 |
72 ... 78 84 |
450
480 507 510 540 |
45.000
48.000 50.750 51.000 54.000 |
±0.030
±0.030 ±0.032 ±0.032 ±0.032 |
120
128 ... 136 144 |
90
96 ... 102 108 |
560
570 600 630 660 |
56.000
57.000 60.000 63.000 66.000 |
±0.032
±0.032 ±0.032 ±0.034 ±0.034 |
... 160 ... ... |
114 120 126 132 |
700
750 770 800 840 |
70.000
75.000 77.000 80.000 84.000 |
±0.034
±0.036 ±0.036 ±0.036 ±0.038 |
140
150 ... 160 ... |
ANSI / RMA IP-24
ISO 5299
IS 9804
- Torque Rating Synchronous Timing Belt Equation and Calculator
- Synchronous Timing Belt Pitches
- Horsepower Rating Synchronous Timing Belt Equations and Calculator
- V Belt Application and Design Considerations
- Motor Shaft Load Due to Belt Loading Equations and Calculator
- Power Transmission by Leather Belting
- V & Flat Belt Design Equations and Formulae
- Flat Belt Design Equations
- Service Factors Synchronous Timing Belts
- V Belt Rated Horsepower Equations | Design Pulley Speed Ratio |Power Calculations V-Belt | Dynamic or Two-Plane Balancing Equation
- Synchronous Timing Belt Pulley Standard Diameters
- Timing Belt Pulley Tolerances per. ANSI RMA IP-24
- Synchronous Timing Belt Standard Widths and Tolerances
- Synchronous Timing Belt Tooth Section Dimensions Table per ANSI / RMA IP-24, ISO 5299 and IS 9804
- Synchronous Timing Belt Lengths and Tolerances per. ANSI RMA IP-24, ISO 5299 and IS 9804
