Air Conditioning Size Calculator and Estimator Chart
This AC size calculator.
This calculator is provided for use to calculate basic size in BTU to adequately cool a room of know size.
The sizing chart below the calculator is useful to help you determine your approximate air conditioner size requirement in Tons.
Preview Calculator AC Required Preview
Estimated Air Conditioning Required in Tons based on Square Footage
Tons |
Zone 1 |
Zone 2 |
Zone 3 |
Zone 4 |
Zone 5 |
1.5 |
600 - 900 sf |
600 - 950 sf |
600 - 1000 sf |
700 - 1050 sf |
700 - 1100 sf |
2 |
901-1200 sf |
951 - 1250 sf |
1001 - 1300 sf |
1051 - 1350 sf |
1101 - 1400 sf |
2.5 |
1201 - 1500 sf |
1251 - 1550 sf |
1301 - 1600 sf |
1351 - 1600 sf |
1401 - 1650 sf |
3 |
1501 - 1800 sf |
1501 - 1850 sf |
1601 - 1900 sf |
1601 - 2000 sf |
1651 - 2100 sf |
3.5 |
1801 - 2100 sf |
1851 - 2150 sf |
1901 - 2200 sf |
2001 - 2250 sf |
2101 - 2300 sf |
4 |
2101 - 2400 sf |
2151 - 2500 sf |
2201 - 2600 sf |
2251 - 2700 sf |
2301 - 2700 sf |
5 |
2401 - 3000 sf |
2501 - 3100 sf |
2601 - 3200 sf |
2751 - 3300 sf |
2701 - 3300 sf |
sf = Square Foot
Zone 1 = Red
Zone 2 = Orange
Zone 3 = Yellow
Zone 4 = Green
Zone 5 = Blue
- Air Conditioning System Design and Analysis Document This is an introduction to air conditioning systems (frequently referred to as HVAC systems – heating, ventilating and air conditioning systems).
- Air Flow Through Opening Caused by Wind Only Calculator
- Dampers HVAC Industrial HVAC dampers are also used to regulate room temperatures or other environmental parameters.
- Heat Gain or Loss HVAC Duct ASHRAE Formula and Calculator . All HVAC ducts exposed to outdoor conditions, as well as those passing through unconditioned or semiconditioned spaces, should be insulated.
- HVAC ASHRAE Psychrometric Chart ASHRAE Psychrometric Chart No.1 Normal Temperature Barometric Pressure: 29.921 Inches of Summary
- HVAC Air Change Out Frequency (minutes) General recommendations for total volume of air change out for selected type indoor air spaces.
- HVAC Air Duct Flow Resistance Chart HVAC duct flow resistancechart. Friction in Inches of Water per 100 Feet Friction of Air in Straight Duct
- HVAC Air Handling Unit Design Excel Calculator
- HVAC Rectangular to Round Duct Equivalent HVAC Rectangular to Round Duct Equivalents
- HVAC Screen Pressure Drop HVAC screen pressure drop graph.
- HVAC / Air Conditioner Size Calculator Spreadsheet Requires an active Premium Membership
