Air Density Table and Specific Weight Equations and Calculator
Engineering Physics
Air Density and Specific Weight Table, Equations and Calculator:
The density of air, ρ (Greek: rho) (air density), is the mass per unit volume of Earth's atmosphere. Air density, like air pressure, decreases with increasing altitude. It also changes with variation in temperature or humidity. At sea level and at 15 °C, air has a density of approximately 1.225 kg/m3 (0.001225 g/cm3, 0.0023769 slug/ft3, 0.0765 lbm/ft3) according to ISA (International Standard Atmosphere).
Specific weight and density of air at standard atmospheric pressure - Imperial Units:
Temperature °F |
Density slugs/ft3 |
Specific Weight lb/ft3 |
-40 |
.002939 |
.09456 |
-20 |
.002805 |
.09026 |
0 |
.002683 |
.08633 |
10 |
.002626 |
.08449 |
20 |
.002571 |
.08273 |
30 |
.002519 |
.08104 |
40 |
.002469 |
.07942 |
50 |
.002420 |
.07786 |
60 |
.002373 |
.07636 |
70 |
.002329 |
.07492 |
80 |
.002286 |
.07353 |
90 |
.002244 |
.07219 |
100 |
.002204 |
.07090 |
120 |
.002128 |
.06846 |
140 |
.002057 |
.06617 |
160 |
.001990 |
.06404 |
180 |
.001928 |
.06204 |
200 |
.001870 |
.06016 |
250 |
.001756 |
.05598 |
300 |
.001624 |
.05224 |
400 |
.001435 |
.04616 |
500 |
.001285 |
.04135 |
750 |
.001020 |
.03280 |
1,000 |
.000845 |
.02717 |
1,500 |
.000629 |
.02024 |
Specific weight and density of air at standard atmospheric pressure - SI Units:
Temperature °C |
Density kg/m3 |
Specific Weight N/m3 |
-40 |
1.514 |
14.85 |
-20 |
1.395 |
13.68 |
0 |
1.293 |
12.67 |
5 |
1.269 |
12.45 |
10 |
1.247 |
12.23 |
15 |
1.225 |
12.01 |
20 |
1.204 |
11.81 |
25 |
1.184 |
11.61 |
30 |
1.165 |
11.43 |
40 |
1.127 |
11.05 |
50 |
1.109 |
10.88 |
60 |
1.060 |
10.40 |
70 |
1.029 |
10.09 |
80 |
0.9996 |
9.803 |
90 |
0.9721 |
9.533 |
100 |
0.9461 |
9.278 |
200 |
0.7461 |
7.317 |
300 |
0.6159 |
6.040 |
400 |
0.5243 |
5.142 |
500 |
0.4565 |
4.477 |
1000 |
0.2772 |
2.719 |
- Density of Common Engineering Materials
- Densities of Metals and Elements Table
- Water Vapor Density
- Density Equation and Review
- Density of Various Solids Tables
- Water - Density Viscosity Specific Weight
- Fluid Characteristics Chart Table | Fluids Data, Fluids Density | Vapor Pressure | Kinematic Viscosity
- Air Density Equation
- Hydrostatic Pressure vs Depth Liquid Table Chart
