Axial Stress Thick Wall Cylinder Equations and Calculator
Pressure Vessel Design Formula and Calculators Resources
If the pressure (pi) is confined at the ends, an axial (longitudinal) stress (σa) is also developed. It is assumed that the external pressure po is zero. The geometry and stresses, including the tangential stress (σt), are shown in Figure 1
Figure 1
Geometry of a cylinder
Preview: Thick Walled Cylinder Axial Stress Calculator
Using the geometry of figure 1 axial stress (σa) is given by:
Axial Stress Formula:
σt = ( pir2i ) / ( r2o - r2i )
pi = internal pressure (psi, MPa),
ri = inside radius (in, m),
ro = external radius (in, m)
- Thick Walled Cylinder Stress Pressure Vessel Equations and Calculator
- Pressure Vessel External Pressure Calculations
- Pressure Vessel, Thin Wall Longitudinal Stress Calculator
- Pressure Vessel, Thin Wall Hoop and Longitudinal Stresses Equation and Calculator
- Pressure Vessel Design Calculations Handbook
- Identifying and Reducing Stresses in Pressure Vessels
Marks' Calculations for Machine Design,
Thomas H. Brown, Jr. Ph.D., PE
Faculty Associate
Institute for Transportation Research and Education
NC State University
Raleigh, North Carolina
