Buckingham Reiner Equation and Calculator
Heat Transfer Engineering
Laminar flow of Bingham plastic fluids friction factor is given by the Buckingham-Reiner equation
τR = [ ( Po - PL ) R ] / 2 L
Q = [ ( π ( Po - PL ) R4 ρ ) / ( 8 µ L ) ] [ 1 - ( 4 τo ) / ( 3 τR ) + 0.333 ( τo / τR )4 ]
Po = Input Pressure (psi)
PL = Output Pressure (psi)
R = Radius or tube (ft)
ρ = Density of Fluid (ppg)
µ = Viscosity of Fluid (cP)
L = Length (ft)
τo = Torsion Stress (psi)
τR = Shear Stress at the Tube Wall (psi)
Q = Mass Flow Rate (lb/s)
ppg = pounds per gallon
cP = Poise
Note: When τo is zero, the Bingham model reduces to the Newtonian model and the final equation presented above reduces appropriately to the Hagen-Poiseuille equation.
Bird, R.B., Stewart, W.E. and Lightfoot, E.N. (2002). Transport Phenomena (Second Ed.). John Wiley & Sons,Chapter: 8, Page: 260.
- A Practical Utilization of the Theory of Bingham Plastic Flow in Stationary Pipes and Annuli Basic membership minimum Required to download
- Brinkman Number Equation and Calculator
- Archimedes Number Calculator
- Einstein Equation Effective Viscosity
- Critical Pressure and Temperature Cavett Correlation Calculation
- Harris Formula for Pressure Change at Standard Conditions Equation and Calculator
- Pressure Losses for Fluid Flow in 90° Pipe Bends
- Volumetric Flow Rate volumetric flow rate (V ) of a system is a measure of the volume of fluid passing a point in the system per unit time.
- Swamee-Jain Friction Factor Equation and Calculator This is another explicit equation for calculating the friction factor typically used in the Darcy-Weisbach.
- Weir Flow Rectangular Open Channel Water Flow Calculator and Formula
