C Section Torque Applied Deformation and Stress Equations and Calculator
Torque Applied Deformation and Stress of a C Beam Section Equations and Calculator
Preview
Torque Applied Deformation and Stress of a C Beam Section Calculator
K = 2Cro4
Varies with ri / ro as follows
For:
Where 0.2 ≤ ri / ro 0.6
θ = ( T L ) / ( K G )
Shear Stress Maximum
At M:
Where B varies with ri / ro as follows:
for 0.2 ≤ ri / ro ≤ 0.6
Where 0.1≤ h / ri ≤ 1.0
θ = angle of twist (radians),
ro, ri = radius (in, mm),
