Circular Ring Analysis No 15 Roarks Formulas for Stress and Strain Equations and Calculator
Circular Ring Moment, Hoop Load, and Radial Shear Equations and Calculator #15.
Per. Roarks Formulas for Stress and Strain Formulas for Circular Rings Section 9, Reference, loading, and load terms #15.
Ring supported at base and loaded by own weight per unit length of circumference w
Circular Ring Loading #15 |
Circular Ring Dimensional Properties |
Resultant moment, hoop load, and radial shear |
Preview: Circular Ring Moment, Hoop Load, and Radial Shear Calculator #15
The radial pressure wx vaies with (x - θ)2 from 0 at x = θ to w at x = π
θ ≥ π / 2
Moment Formula
Note: The constant KT accounts for the radial distribution of mass in the ring.
Hoop Stress Formula
Radial Shear Fomula
VA = 0
Note: Loads beyond 180° not supported in load terms equations.
〈 x - θ 〉0
α = e / R for thick rings
α = I / AR2 for thin rings
A = π [ R2 - Ri2 ]
β = FEI / GAR2 for thin rings
k1 = 1 - α + β
k2 = 1 - α
Plastic section modulus
F = Z / I c
Z = Zx = Zy = 1.33R3
Change of Length of Cylinder
W = load (force);
Z = Plastic section modulus
v = Poisson’s ratio;
t = wall thickness
s = sin θ
c = cos θ
z = sin x,
u = cos x
n = sin Φ
m = cos Φ
α = Hoop stress deformation factor
β = Transverse (radial) shear deformation factor
〈 x - θ 〉0
if x < 0, 〈 x - θ 〉0 =0;
if x > 0, 〈 x - θ 〉0 =1;
Roarks Formulas for Stress and Strain, 7th Edition, Table 9.2 Reference No. 15, loading, and load terms.
