Circular Ring Analysis No. 6 Roarks Formulas for Stress and Strain Formulas and Calculator
Circular Ring Moment, Hoop Load, and Radial Shear Equations and Calculator #6.
Loading W at θ relative to D-B
Per. Roarks Formulas for Stress and Strain Formulas for Circular Rings Section 9, Reference, loading, and load terms #6.
Circular Ring Loading #6
Circular Ring Dimensional
Properties
Resultant moment, hoop load, and radial shear
Preview: Circular Ring Moment, Hoop Load, and Radial Shear Calculator #6
Moment
Hoop Stress
N = NA u + Va z + LTN
Radial Shear
V = - NA z + VA u + LTv
LTM = -WR [ 1 - cos( x-θ ) ] ⟨ x - θ ⟩0
LTN = W cos( x - θ ) ⟨ x - θ ⟩0
LTv = -W sin( x - θ ) ⟨ x - θ ⟩0
Unit step function defined by use of ⟨ ⟩, See explanation at bottom of page.
⟨ x - θ ⟩0
MA = ( -W R ) / π [ s + k2 ) - ( pi() - θ ) ( 1 - c ) ]
MC = ( -W R ) / π [ s ( k2 - 1 ) + θ ( 1 + c ) ]
NA = ( -W / π ) [ s ( π - θ ) c ]
VA = 0
α = e / R for thick rings
α = I / AR2 for thin rings
A = π [ R2 - Ri2 ]
β = FEI / GAR2 for thin rings
k1 = 1 - α + β
k2 = 1 - α
Plastic section modulus
F = Z / I c
Z = Zx = Zy = 1.33R3
Change of length of Circular Ring
Change of length @ W loads
Change of length @ W loads horizontally
Angular rotation
Angular rotation
W = load (force);
Z = Plastic section modulus
v = Poisson’s ratio;
t = wall thickness
s = sin θ
c = cos θ
z = sin x,
u = cos x
n = sin Φ
m = cos Φ
⟨ x - θ ⟩0
if x < 0, ⟨ x - θ ⟩0 =0;
if x > 0, ⟨ x - θ ⟩0 =1;
At x = θ the unit step function is undefined just as vertical shear is undefined directly beneath a concentrated load. The use of the angle brackets ⟨ ⟩ is extended to other cases involving powers of the unit step function and the ordinary function ⟨ x - a ⟩n
Thus, the quantity ⟨ x - a ⟩n ⟨ x - a ⟩0 is shortened to ⟨ x - a ⟩n and again is given a value of zero if x < a and is ( x-a )n if x > a.
Roarks Formulas for Stress and Strain, 7th Edition, Table 9.2 Reference No. 5, loading, and load terms.
