Circular Ring Loading Analysis no 10 Equations and Calculator. Per. Roarks Formulas for Stress and Strain F
Circular Ring Moment, Hoop Load, and Radial Shear Equations and Calculator #10.
Per. Roarks Formulas for Stress and Strain Formulas for Circular Rings Section 9, Reference, loading, and load terms #10.
![]() Circular Ring Loading #10 |
Preview: Circular Ring Moment, Hoop Load, and Radial Shear Calculator #10
θ ≥ π / 2
Moment
Hoop Stress
N = NA u + Va z + LTN
Radial Shear
V = - NA z + VA u + LTv
LTM = - w R2 / 2 ( c - u )2 〈 x - θ 〉0
LTN = w R u ( c - u ) 〈 x - θ 〉0
LTv = - w R z ( c - u ) 〈 x - θ 〉0
〈 x - θ 〉0
VA = 0
α = e / R for thick rings
α = I / AR2 for thin rings
A = π [ R2 - Ri2 ]
β = FEI / GAR2 for thin rings
k1 = 1 - α + β
k2 = 1 - α
Plastic section modulus
F = Z / I c
Z = Zx = Zy = 1.33R3
Change of length of Circular Ring
W = load (force);
Z = Plastic section modulus
v = Poisson’s ratio;
t = wall thickness
s = sin θ
c = cos θ
z = sin x,
u = cos x
n = sin Φ
m = cos Φ
〈 x - θ 〉0
if x < 0, 〈 x - θ 〉0 =0;
if x > 0, 〈 x - θ 〉0 =1;
Roarks Formulas for Stress and Strain, 7th Edition, Table 9.2 Reference No. 10, loading, and load terms.
