Circular Ring Moment Loading 3 Formulae and Calculator
Circular Ring Moment, Hoop Load, and Radial Shear Equations and Calculator #3 .
Loading moment applied Mo at θ relative to x angle
Per. Roarks Formulas for Stress and Strain Formulas for Circular Rings Section 9, Reference, loading, and load terms #3.
![]() Circular Ring Loading #2 |
Preview: Circular Ring Moment, Hoop Load, and Radial Shear Calculator #3
Moment
Hoop Stress
N = NA u + Va z + LTN
Radial Shear
V = - NA z + VA u + LTv
LTM = Mo 〈 x - θ 〉0
LTN = 0
LTv = 0
〈 x - θ 〉0
MA = - Mo / π [π - θ - ( 2 s k2 ) / k1 ]
MC = Mo / π [ θ - ( 2 s k2 ) / k1 ]
NA = [ Mo / ( R π ) ] ( 2 s k2 ) / k1
VA = 0
α = e / R for thick rings
α = I / AR2 for thin rings
A = π [ R2 - Ri2 ]
β = FEI / GAR2 for thin rings
k1 = 1 - α + β
k2 = 1 - α
Plastic section modulus
F = Z / I c
Z = Zx = Zy = 1.33R3
Change of length of Circular Ring
W = load (force);
Z = Plastic section modulus
v = Poisson’s ratio;
t = wall thickness
s = sin θ
c = cos θ
z = sin x,
u = cos x
n = sin Φ
m = cos Φ
ΔL = Change in lower half of vertical diameter the vertical motion relative to point C of a line connecting points B and D on the ring,
〈 x - θ 〉0
if x < 0, 〈 x - θ 〉0 =0;
if x > 0, 〈 x - θ 〉0 =1;
Roarks Formulas for Stress and Strain, 7th Edition, Table 9.2 Reference No. 3, loading, and load terms.
