Column Loading and Elastic Stability Case 2d Formulae and Calculator
Column Loading and Elastic Stability Formulae and Calculator Case 2d
Stepped straight bar under tensile end load P1 and intermediate load P2; upper end pinned, lower end fixed.
Preview: Column Loading and Elastic Stability Calculator Case 2d
NOTATION:
P1' = critical load (force) (lbs, N);
p' = critical unit load (force per unit length), (lbs, N);
T' = critical torque (force-length A.R.) (in-lbs, N-mm);
M' critical bending moment (force-length);
l = Length of bar (in, mm),
K1 = Derived from ratios as follows (see table):
1.) ( E2 I2 ) / ( E1 I1
2.) a / l
3.) P1 / P2
Formulae:
P'2 = ( K2 π2 E1I1 ) / l2
