Column Loading and Elastic Stability Case 2e Formulae and Calculator
Column Loading and Elastic Stability Formulae and Calculator Case 2e.
Stepped straight bar under tensile end load P1 and intermediate load P2 both ends fixed.
Preview: Column Loading and Elastic Stability Calculator Case 2e
NOTATION:
P1 = Load (force) (lbs, N);
P2 = Load load (force) (lbs, N);
p' = critical unit load (force per unit length), (lbs, N);
T' = critical torque (force-length A.R.) (in-lbs, N-mm);
M' critical bending moment (force-length);
l = Length of bar (in, mm),
K2 = Derived from ratios as follows (see table):
1.) ( E2 I2 ) / ( E1 I1 )
2.) a / l
3.) P1 / P2
Formulae:
P'2 = ( K2 π2 E1I1 ) / l2
