Compressibility of Liquids Formulae and Calculator
Compressibility of Liquids Equations and Calculators
If v1 and v2 are the volumes of the liquids at pressures of p1 and p2 atm, respectively, at any temperature, the coefficient of compressibility b is given by the equation
The value of b x 106 for oils at low pressures at about 70°F varies from about 55 to 80; for mercury at 32°F, it is 3.9; for chloroform at 32°F, it is 100 and increases with the temperature to 200 at 140°F; for ethyl alcohol, it increases from about 100 at 32°F and low pressures to 125 at 104°F; for glycerin, it is about 24 at room temperature and low pressure.
Sources:
Marks Standard Handbook for Mechanical Engineers
- Compressibility of a Fluid Equations and Calculator
- Harris Formula for Pressure Change at Standard Conditions Equation and Calculator
- Head Changes Caused by Pipe Size Enlargement Formula and Calculator
- Head Changes Caused by Pipe Size Sudden Reduction Formula and Calculator
- Hydraulic Turbine Actual Power Formula and Calculator
- Hydraulics Field Manual and Training - 173 pages, free membership required
- Hydraulic Jump Conjugate Depths Equations and Calculator
- Hydrostatic Pressure Force of a Fluid On Vessel Planes Equations The hydrostatic force of pressure F is that force which is exerted on the wall by the fluid only - i.e. without consideration of pressure p 0 .
- Hydrostatic Discharge of Liquid From Vessel Bottom Equations and Calculator
- Impulse-Momentum Principle For Fluids Formula The Impulse-Momentum Principle is derived from Newton's 2nd law in vector form
- Siphon Flow and Discharge Rates Tables and Charts
- Siphon Flow Rate from Small Pipes Equation and Calculator
- Siphon Discharge Rate Equations and Calculator
- Unwin Gas Change of Pressure and Calculator and Formulas The Unwin formula has been successfully used in steam piping calculations for many years.
- Water Vapor Density atmosphere Equation - Water vapor in the atmosphere obeys the ideal gas law,
- Vapor Pressure Spreadsheet Calculator
- Viscosity of a Pure Liquid Estimation Equation and Calculator
- Viscosity Grade Table ISO 3448
- Viscous Torque and Power on Rotating Shafts Equations and Calculator
- Volume of Water as a Function of Pressure and Temperature
- Weymouth Pressure and Flow Formula and Calculator
- Water Vapor Permeability Diffusive transfer of water vapor through porous materials is often described by a modified form of Fick's law
