Concentrated Angular Displacement 4 Deflection Equation and Calculator
Concentrated Angular Displacement on the Horizontal Member Elastic Frame Deflection Left Vertical Member Guided Horizontally, Right End Pinned Equation and Calculator.
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Moment Calculator:
Since ψA = 0 and HA = 0
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
